Confused and need help!!!!!!
  • gr8funbikes
  • gr8funbikes's Avatar Topic Author
03 Mar 2006 15:57
#27940
Hello everyone. I am new here and have a silly question. I have a 82' kz 750 CSR twin. I was told that it was a 2 stroke but I read some where that it was a four stroke. Was wonderin which is it? Also if it is a two stroke is it oil injected and where does the oil go. It is my first bike and the best part is it's a KZ.
82 KZ 750 CSR Twin
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Confused and need help!!!!!!
03 Mar 2006 16:03
#27943
Well, Kaw made a 750 2 stroke, but it was in the 70's and was a three cylinder. You twin is a definite 4 cycle. Your only concern with oil is regular motor oil in the crankcase. Welcome to the site! We need pictures of your bike, it is mandatory!!:P
The Kaw List:
  • 77KZ650
  • 77KZ650's Avatar
03 Mar 2006 16:04
#27944
4 stroke, look at the pipes, if they dont flare out and then get skinny again, its a 4 stroke, also, look at the head, if theres valves, its a 4 stroke (with the exception of power valves on some new snomobiles, but they are part of the exhaust, and not in the head) the head will be really small if there arent valves
07 MDP Rookie of the Year
  • gr8funbikes
03 Mar 2006 16:07
#27945
Thanks 79mkll. I will get as many pics as I can. I am going to be customizing it very soon. Right now it is stock and I have a bunch of goodies to put on it. I will post pics on my progress as soon as I start.
82 KZ 750 CSR Twin
  • gr8funbikes
03 Mar 2006 16:09
#27948
thanks 77KZ650. It is deffinitly a 4 stroke. Thakns for the info.
82 KZ 750 CSR Twin
  • steell
  • steell's Avatar
03 Mar 2006 17:12
#27958
Two cylinder four stroke 748cc inline twin with dual carbs and electronic ignition. The 82 750 CSR has no centerstand and has leading axle forks (axle mounts on front of fork tubes), 16" rear spoke wheel with a 19" front spoke wheel, stepped seat with buckhorn handlebars (stock ones do anyway), and a vacume operated petcock.
And it won't shift into second gear unless the bike is moving (common question from new KZ owners).
Anything in particular you want to know, just ask :D
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
03 Mar 2006 17:18
#27959
Geeze, don't have any detailedinformation??:P
The Kaw List:
  • wireman
  • wireman's Avatar
03 Mar 2006 17:54
#27971
hell i thought someone posted my biography!:whistle:
