Engine running temps
- eclipse30gt
07 Apr 2009 08:08 #279167
by eclipse30gt
Engine running temps was created by eclipse30gt
Does anyone know what the running engine temp might be on the 1000 J motors? I'm getting my engine powder coated and just wanted to check and see before I picked out the paint.
Thanx,
Thanx,
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
07 Apr 2009 08:55 #279173
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Engine running temps
Hi eclipse30gt.
Can't help you myself but there was a thread a while ago on here where someone had a fancy hi temp device and they listed temps on various parts of a kz engine. If I recall correctly the header temp was very high.[1300?].
All the Best.
All the Best.
1980 KZ500 B2
- Captaingamez
07 Apr 2009 09:02 #279175
by Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
Replied by Captaingamez on topic Engine running temps
just get something that will stand 500 degrees and that should be good for any engine parts, if they are getting hotter than that, your in big trouble anyway. liquid cooled's run around 230 when they are hot air cooled can run up to 100 to 150 degrees hotter than that.
for the pipes you should go with the highest temp stuff you can find. pipes can get very very very hot, up to 2000 degrees in some cases.
1971 Yamaha AT1
1971 Skiroule 300rr
- eclipse30gt
07 Apr 2009 10:30 #279182
by eclipse30gt
Replied by eclipse30gt on topic Engine running temps
thanx kids....
- stardon
07 Apr 2009 19:49 #279333
by stardon
Replied by stardon on topic Engine running temps
I painted my engine with DP series Epoxy primer and PPG Acrylic Enamel. Even around the exhaust ports on the head it's holding up without any bubbling or peeling. When I first got my GPZ running I used a IR temp gun, the temp's I got at the back of the cyl's was around 250F. I thought it would be be hotter, apparently the fins do a good job at getting rid of the heat.
