Timing Question?
- Oldwolf
05 Apr 2009 04:48 #278541
by Oldwolf
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
Timing Question? was created by Oldwolf
While playing with a New Meter checking my Idle and Timing I found that the Right Side Dyna S module is firing 1-4 plugs and the Left side is firing 2-3. I believe this is opposite of what should occur. 1105CC Kit was put in about 10 years ago. Whats the answer? How to Correct? Thanks.
- roy-b-boy-b
- Thank you received: 103
05 Apr 2009 05:02 #278543
by roy-b-boy-b
Replied by roy-b-boy-b on topic Timing Question?
You can take off the dyna button on the crank and turn it 180 degrees. roy
- loudhvx
- Thank you received: 1616
05 Apr 2009 05:27 - 05 Apr 2009 05:30 #278549
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Timing Question?
As Roy said, you can pull the rotor off the advancer, and re-install it 180 degrees flipped.
Then you have to correct the wiring. That's the wires to the coils, and/or the plug wires.
Normally the left coil has a black wire and the right coil has a green wire. The left coil fires 1,4 and the right coil fires 2,3.
I'm not sure if the Dyna uses the same colors for the coil wires, though.
1981 KZ550 D1 gpz.
Other links.
Last edit: 05 Apr 2009 05:30 by loudhvx.
- Old Man Rock
- Thank you received: 225
05 Apr 2009 09:04 #278600
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Timing Question?
Follow the link, should help out... Tutorial on Dyna S Installation....
members.cox.net/ruinsofstei/Dyna%20S%20D...ation%20by%20OMR.pdf
It doesn't truly matter which side the 1/4 coil resides in physically, what does matter is which pick up conductor is terminated to it for 1/4 operations...
NOTE: Normally/OEM is as sitting on bike, 1/4 is on the left side under the tank.
In review of the image from the Dyna S pick ignition up plate, the WHITE conductor with the little black heat shrink is for the 1/4 coil...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Oldwolf
06 Apr 2009 04:40 - 06 Apr 2009 21:56 #278822
by Oldwolf
Replied by Oldwolf on topic Timing Question?
Thanks Guys You were right the Dyna S button was installed with the Magnet to the right or on the 2-3 side. Thanks again Folks.
Last edit: 06 Apr 2009 21:56 by Oldwolf.
