kz twin b3 /750 twin g ?????????
- grace1
04 Apr 2009 16:13 #278406
by grace1
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
kz twin b3 /750 twin g ????????? was created by grace1
hi all saw a set of headers (cut) of a g model twin will these be similiar raised angle compared to my old b3 headers not sure what the diff was from a b3 4 to the g
he has a set of mikunis too i thought the g had diff carbs and polution gear on the top of head cover for breather or was that the csr later
too looking for a b4 seat for a mate in oss can anyone help
thanks graeme
thanks graeme
- bountyhunter
- Thank you received: 337
04 Apr 2009 22:57 - 04 Apr 2009 22:59 #278530
by bountyhunter
Replied by bountyhunter on topic kz twin b3 /750 twin g ?????????
I have a B4 (no you can't have my seat, I just got it recovered)..... everytime I have seen aftermarket headers listed, they just say "750 twin" which leads me to believe that pipes that fit any 750T could be made to fit any of the 750 twin models if you can rig up someway to hang them.
I know the carbs are not all the same on the various 750 twins, as I bought some vacuum pistons off an '81 that was different than the ones on my '79. They may all be "BS 38" types, but the jets and pistons may not be identical.
Last edit: 04 Apr 2009 22:59 by bountyhunter.
- grace1
05 Apr 2009 00:13 #278532
by grace1
Replied by grace1 on topic kz twin b3 /750 twin g ?????????
cheers bounty ,yep i knew about the different carbs i think the later t ,s went to a 34mm mik ? how did you do with your carb r/h pop prob ,i had a very same prob ,found it was the butterfly synch , tried needle adj etc and at last minute a mech said i reckon that r/h butterfly was just a tad lazy it only took a smidgin of a turn to make it idle and run so much better
cheers graeme
cheers graeme
- bountyhunter
05 Apr 2009 13:49 #278660
by bountyhunter
All of my recent carb (and lean running) problems stemmed from the fact the rubbers attached to the vacuum pistons had VERY TINY slits that leaked air and I could not see them... until I really looked. That made it run lean at light throttle openings and I was trying to compensate with pilot jets and needle position... which worked pretty well. I installed new pistons with good rubbers and went back to stock needle position and it runs pretty well now.
