75 KZ400 Engine Knock
- Pbisesi
04 Apr 2009 07:00
Hi guys
I've been lurking for a while this winter.
I picked a 75 KZ400 to build for my wife to learn to ride.
I did it in a Low Rider style. She couldn't sit flat footed on the stock bike.
Any way, I finally got it outside and started it up.
It seemed to run OK. Yesterday When I went to start it I got a loud squeeling sound. This morning I turned it over again and it started right up, but seems to have a knock.
I think it's in the top half.
I don't know much about these bikes.
Any ideas?
Thanks
Pat
Any ideas?
Thanks
Pat
- oldkaws4ever
- Have no regrets...... You only live once.
Re: 75 KZ400 Engine Knock
04 Apr 2009 08:00
Was it cold out? My 76 kz 400 squeels like like a pig when its cold out and it gets started. The knocking is probally again due to the fact there was no to little oil in the top end. I would say to let it warm up and take it for a ride and see if the knock goes away.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Pbisesi
06 Apr 2009 10:41
Found a video of what my bike sounds like.
Any ideas?
Any ideas?
- flht1997
06 Apr 2009 10:58
there is not a tensioner on the primary chain and they can make a bit of noise when they are on the sidestand, does the noise change when you right the bike? also balancing the carbs can help some.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- timebomb33
06 Apr 2009 11:01
pull in the clutch and see if the noise goes away, or as has been suggested get the carbs sync'd.
I THINK MY POWERBAND BROKE
- bountyhunter
06 Apr 2009 12:41
Pbisesi wrote:
The twins seem to be notorious for bad starter clutches. I read they can make noise.Hi guys
Any ideas?
Thanks
Pat
- gane
06 Apr 2009 13:04
Pat. little or no help, The periodic rumble I hear before blipping throttle sounds charistic of cam chain and/ or clutch basket. does it go away after up to temp? G
[img][/img] 1977 KZ1000A1
