- Thank you received: 25
Question for Leon
- T_Dub
03 Apr 2009 12:04 #278082
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Question for Leon was created by T_Dub
Other people can probably answer this but I know Leon can. When boring cylinders, what clearance do you leave between the walls and the pistons before the hone? I want to bore my cylinders myself and get the local shop to hone, because they have the correct machine. I really dont see the need to pay someone over $100 to bore though when I can do that myself easily.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- arai59
- Banned
- Thank you received: 1
03 Apr 2009 12:27 - 03 Apr 2009 12:28 #278086
by arai59
Replied by arai59 on topic Question for Leon
You have the correct machine to bore cyclinders ? Boring is precision work. Honing is nothing.
Last edit: 03 Apr 2009 12:28 by arai59.
- T_Dub
03 Apr 2009 12:33 - 03 Apr 2009 12:35 #278087
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Question for Leon
I get within a tolerance of .005" normally, I'd imagine thats good enough. .002" is possible if I'm careful.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Last edit: 03 Apr 2009 12:35 by T_Dub.
- bountyhunter
- Thank you received: 337
03 Apr 2009 13:38 #278107
by bountyhunter
Replied by bountyhunter on topic Question for Leon
T_Dub wrote:
.005" is definitely not good enough for boring cylinders. Standard clearance spec for piston to cylinder on mine is .0016" - .0028". BTW: pistons taper top to bottem and are widest at the skirt. The machine shop that did mine required I give them the pistons so they could measure them, then they marked them to the hole they were matched to.I get within a tolerance of .005" normally, I'd imagine thats good enough. .002" is possible if I'm careful.
- T_Dub
03 Apr 2009 13:42 #278109
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
Alrighty, I'll get the shop to do it then, after I get my pistons, so they can measure. I actually meant .0005, but it'd suck if I screwed it up.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
- Thank you received: 109
03 Apr 2009 14:11 #278113
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Question for Leon
The pistons are measured near the bottom. i dont think all manufacturers use the same spot. J&E measures 1/2" up from the bottom, front to back. they may be oval shaped as well.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
