- Thank you received: 2
650/750 gasket
- pburnhamb
01 Apr 2009 15:07 #277471
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
650/750 gasket was created by pburnhamb
Alright Im almost ready to put an order in at Z1 but I have a question or two first. The 750 base gasket will fit my bored 650 cases correct? this is the gasket i need?
I can just run a hose between the 2 nipples on the valve cover for the air injection system and be done with it? or is there a need to block the passageways into the valves? will this Affect anything?
thanks for your help.
1976 kz900
1977 xs650
- rstnick
- Thank you received: 377
01 Apr 2009 17:05 - 01 Apr 2009 17:09 #277491
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic 650/750 gasket
The 750 base gasket is shared by these models:
Model (26):
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-F1 (LTD Shaft) (1983)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ750-L3 (1983)
KZ750-N1 (Spectre) (1982)
KZ750-N2 (Spectre) (1983)
KZ750-R1 (GPz) (1982)
ZN700-A1 (LTD Shaft) (1984)
ZN700-A2 (LTD Shaft) (1985)
ZR750-C1 (Zephyr 750) (1991)
ZR750-C2 (Zephyr 750) (1992)
ZR750-C3 (Zephyr 750) (1993)
ZX750-A1 (GPz 750) (1983)
ZX750-A2 (GPz 750) (1984)
ZX750-A3 (GPz 750) (1985)
ZX750-E1 (GPz 750 Turbo) (1984)
ZX750-E2 (GPz 750 Turbo) (1985)
Yours being a '78, there's got to be a little difference.
The cylinder head gasket is shared by these models:
Model (30):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
You can run a hose between the 2 nipples on the valve cover for the air injection system, but you will also need to adress the other connects by the air box and carb? Not sure as I've never had one with the system.
Model (26):
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
Model (30):
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: 01 Apr 2009 17:09 by rstnick.
- pburnhamb
01 Apr 2009 17:49 #277507
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic 650/750 gasket
well she has no airbox. im getting some bs34 carbs and pods, so i guess all i have to do is connect the two nipples with a hose.....
yeah she is a 78, i guess i need to bet the base and valve cover gasket ontop of the 650 whole set...
1976 kz900
1977 xs650
