Installing pistons
- stever
Installing pistons
01 Apr 2009 12:14
Put the barrels on at the weekend its a 1075 kit so the bore had taken most of the chamfer off the bottom of the barrels. I dont have a ring compressor!
Put assembly grease on the rings and in the bore then cut a 1 inch wide strip of plastic off an old pets dring bottle long enough to wrap round the rings cut small tabs at the top and bent it back so the plastic would get carried down as i pushed the barrels down. I then used plastic cable ties to wrap round the plastic and compress the rings, slid the barrels on and the pistons just went straight in with no problems at all.
I figured by using plastic I could not scratch the pistons or any thing.
Once the pistons were in I just cut the cable ties and pulled the plastic off.
It only took a few minutes and cost nothing.
Just thought someone else might find this usefull.
- Mcdroid
- Gone Kwackers
Re: Installing pistons
01 Apr 2009 12:18
Good post...thanks stever!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- mark1122
- Keep twisting it
01 Apr 2009 12:41
Good idea.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
01 Apr 2009 15:25
Seems like a good approach. Many of the net posters also claim they use large hose clamps as ring compressors with good luck. I never tried them.
- KZ 82 750 LTD Guy
- KZ 82 750 LTD Guy
01 Apr 2009 15:38
You goys still around have a few questions ,,,im new !!!
