Transmision Popping out of gear
- Stevec6535
01 Apr 2009 11:41 #277412
by Stevec6535
Transmision Popping out of gear was created by Stevec6535
Whats up guys. I have a 1980 KZ750 H1. My Transmision pops out of 2nd gear during hard decelleration then pops back in as the bike slows down a little bit. What could be causing this? any advice would be great
Thanks
Thanks
- timebomb33
- Thank you received: 10
01 Apr 2009 11:43 #277414
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Transmision Popping out of gear
bent shift fork or pounded out shift dogs on second gear
- Stevec6535
01 Apr 2009 11:47 #277417
by Stevec6535
Replied by Stevec6535 on topic Transmision Popping out of gear
Pounded out shift dogs?
- timebomb33
01 Apr 2009 11:49 #277419
by timebomb33
the engagement dogs that are on the gears to lock them to gether when you shift
- Stevec6535
01 Apr 2009 11:52 #277420
by Stevec6535
If that is the problem, is it a easy fix?
- T_Dub
- Thank you received: 25
01 Apr 2009 11:55 #277421
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Transmision Popping out of gear
Sure, just get some forks and a shift drum for good measure, split the cases, install, re-assemble. Thats diving pretty deep into your engine, but I dont think it'd be too hard as long as you ahve a service manual.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- mark1122
- Keep twisting it
- Thank you received: 109
01 Apr 2009 12:38 #277440
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Transmision Popping out of gear
U can drop the pan and look up into the trany . but to repair the dogs u need to split the cases and replcae the gears. the forks can be removed while the motor is together. at least on a KZ900/1000.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- MDawnz1
- Thank you received: 27
03 Apr 2009 11:22 #278077
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic Transmision Popping out of gear
Try moving your shift lever up 1 tooth on the splines .
I'm not kidding , try it first , it's free ,,,,,,,
1974 Z1a, still 903
