- Thank you received: 1
emissions crap for 550
- stillbill
31 Mar 2009 21:18 #277252
by stillbill
emissions crap for 550 was created by stillbill
Bought a 1980 550a...im not too hip on the emmissions stuff...im old school...lol...had a z1r\tc tho ...was wondering if i can get rid of that stuff..and just rejet the carbs and plug the head...also...im hip on brits and we do the Boyer ign....anyone had a elec. ig?...that works?...the boyer is...lets just say...crap
- Bluemeanie
- Thank you received: 14
01 Apr 2009 05:03 #277304
by Bluemeanie
Replied by Bluemeanie on topic emissions crap for 550
You can just remove all hoses and air valve. Be sure to plug off open vacuum ports. Then run a hose from plate to plate on front valve cover. No re-jetting required on smog removal.
- loudhvx
- Thank you received: 1616
01 Apr 2009 05:48 #277323
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic emissions crap for 550
What Bluemeanie said.
Also, the best electronic ignition, in my opinion would be a stock electronic ignition from later KZ550A, C, D, or H models. They bolt in, but to get the full benefit you'll want the elec. ign. coils too, or new 3-ohm coils. You could also get a Dyna S ignition, but for that you can use the stock points coils, but if they are originals they are getting old so new 3 ohm coils would work well there too.
1981 KZ550 D1 gpz.
Other links.
