Popping out the right side exhaust? Need help
- Techhead0_3
31 Mar 2009 15:36 #277097
by Techhead0_3
1980 KZ750G1 LTD
Popping out the right side exhaust? Need help was created by Techhead0_3
My 1980 Kz750 G Twin is popping out the exhaust on the right side. I have been chasing it for almost two years. I have all new points, plugs, wires and coil pack. At first I could play with the carburator sync and it would be fine for a while. Now it doesn't want to idle. I have pulled apart the carbs and cleaned them and still no luck. Any tips or ideas would be greatly appreciated
Thanks
Thanks
1980 KZ750G1 LTD
- bountyhunter
- Thank you received: 337
31 Mar 2009 15:39 - 31 Mar 2009 15:40 #277098
by bountyhunter
Replied by bountyhunter on topic Popping out the right side exhaust? Need help
1) Do a mechanical sync on the carbs so the butterflies are open the same amount at idle.
2) Set the fuel levels in the bowls using clear tube.
3) Clean the bowls and jets in the bowls. If these are Mikuni BS-38 like on my 750 twin, the main jets and pilot jets are in the bowl assembly.
4) Check and see which pilot jet you have: if it is a 45, you may want to go up to either 47.5 or 50. Popping usually is from a lean condition.
5) check for intake manifold leaks.
Last edit: 31 Mar 2009 15:40 by bountyhunter.
- Techhead0_3
31 Mar 2009 15:44 #277101
by Techhead0_3
1980 KZ750G1 LTD
Replied by Techhead0_3 on topic Popping out the right side exhaust? Need help
Thanks for responding, an idea where I can but those new jets?
1980 KZ750G1 LTD
- farkwar
31 Mar 2009 17:09 #277126
by farkwar
78 kz1000 B2 LTD 1075cc 9 to 1 compression
02 ZG1000
95 KLR
03 EX500
Replied by farkwar on topic Popping out the right side exhaust? Need help
I had same problem with kz1000. ex cam bad,round part out of round. check clearance at all round cam radis. if bad check web cams for upgrabe ape sells them.
:woohoo:
:woohoo:
02 ZG1000
95 KLR
03 EX500
- stillbill
- Thank you received: 1
31 Mar 2009 21:51 #277258
by stillbill
Replied by stillbill on topic Popping out the right side exhaust? Need help
im a idiot...but id check the head gasket...its ez...start the bike and take a propane torch...while its running just ...now i didnt say spray it...just give it a little spritz slowly...see if it gets rpms///sometimes the gasket...more likely the head warps...not torked right..or a pin is missing from the head and its shifting a little...it heats up and shifts....check your commpression first...if its wild and if it sat a few years that might be it...check the commpression first..ok....didnt i say i was a idiot..lol
- bountyhunter
31 Mar 2009 22:00 - 31 Mar 2009 22:04 #277261
by bountyhunter
Techhead0_3 wrote:
They are the widely available BS30/96 types if my old brain is firing tonight.
Try Z1 Enterprises first.
If they don't have them, go here:
www.psep.biz/store/mikuni_pilot_jet.htm
Last edit: 31 Mar 2009 22:04 by bountyhunter.
