- Thank you received: 300
cam i.d.
- Nebr_Rex
31 Mar 2009 08:27 #277003
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
cam i.d. was created by Nebr_Rex
I have an exhaust cam for a kz900/1000 that someone ground the stamping on the end off.The cam has .345 lift and degreed out at over 300* @ 0 lift or 36* more than a WEB 247.Opening and closing ramps are very steep which gives it a wide nose instead of a sharper pointed one like most other cams.It runs real good with a WEB 247 intake(105 i/113 e,1015 10/1,stock carbs and air box and exhaust in a '79 kz1000st).Just wondering if anybody could tell me what cam company ground this cam?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- larrycavan
- Visitor
31 Mar 2009 17:36 #277138
by larrycavan
Replied by larrycavan on topic cam i.d.
If you wrote down your durations at various common check points, you might be able to nail it down fairly easy.
Andrews use .030
Megacycle uses .040
Cam Motion uses .040 & .050
Web....well you already know theirs....
Andrews use .030
Megacycle uses .040
