- Thank you received: 92
Cleaning cooling fins on cylinders before boring..
- Tyler
29 Mar 2009 19:40 - 29 Mar 2009 19:44 #276601
by Tyler
By t_f_b , shot with Canon PowerShot SD400 at 2009-03-29
The above pictures where taken after a trip to the car wash and a good de-greasing. Typical old nasty cylinders, corrosion, dirt, and engine grime. I used a few differnt tools to clean them that worked very well. To start I used a .45 cal brass rifle cleaning brush in a cordless drill to get most of the corrosin off. Then I switched to a nipple brush (for cleaning bottles) that I cut the handle off of and used in the drill. I also used a rod form the rifle cleanning kit push the brass brush between the cylinders. After I brushed off all the corrosion and dirt I used Black Magic mag wheel cleaner. It's the ammonia in the cleaner that does the work. I did try a 10% cleaning solution with ammonia but the fumes where AWFUL! After a few rinses with the mag wheel cleaner this was the result. Not too bad. Now off the the machine shop.
This process is always such a chore, I hope this gives a some of you few ideas.
"74 Yamaha DT 400 Enduro
Cleaning cooling fins on cylinders before boring.. was created by Tyler
Last edit: 29 Mar 2009 19:44 by Tyler.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
29 Mar 2009 20:38 #276622
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Cleaning cooling fins on cylinders before borin
VERY nice work !!!!:woohoo: I woulda bet that those had been ultrasonically cleaned. Too bad they wouldn't stay like that forever....
- HerrDeacon
30 Mar 2009 02:55 #276675
by HerrDeacon
Replied by HerrDeacon on topic Cleaning cooling fins on cylinders before borin
Wow, they came out awesome. I just finished cleaning mine (never came out anywhere close to yours). There was a load of baked on mud that was murder to get off.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
30 Mar 2009 05:55 #276686
by tachrev
Build Thread
Replied by tachrev on topic Cleaning cooling fins on cylinders before borin
HerrDeacon wrote:
Looks good...the mag wheel cleaner is a good idea.Wow, they came out awesome. I just finished cleaning mine (never came out anywhere close to yours). There was a load of baked on mud that was murder to get off.
Build Thread
