Manual Cam Chain Tensioner adjustment ??s
- po boy
29 Mar 2009 13:41 #276444
by po boy
1980 KZ750E1
2002 Hayabusa
Manual Cam Chain Tensioner adjustment ??s was created by po boy
What is the correct way to install and adjust a manual cam chain tensioner? I just adjusted the valves on my KZ750E1, and put the cam cover back on. The bike came with a APE manual cam chain tensioner. I've never messed with one before, and have no clue exactly how tight it should be set.
1980 KZ750E1
2002 Hayabusa
- Samwell
- Thank you received: 1
29 Mar 2009 13:55 #276451
by Samwell
Replied by Samwell on topic Manual Cam Chain Tensioner adjustment ??s
po boy wrote:
They're pretty easy to set. Loosen the locking nut, back it off a few turns (to make sure it wasn't too tight in the first place) tighten it in until you feel resistance, then back it off 1/4 turn, hold it in place while you tighten the locking nut.
Hope this helps...Sam
