KZ550 Project - Need opinions
- insignia100
28 Mar 2009 21:29 #276256
by insignia100
1983 Kawasaki KZ550
KZ550 Project - Need opinions was created by insignia100
Okay, a little bit of background info. I bought this bike back in November and, due to school, weather, and other obligations, it sat without running until February. When I finally got a chance to fire it up (on a warmish day, of course) and found that it was running rough, missing on one cylinder, and needed the choke on full to stay running. First order of business was to replace all the spark plugs. Well, that didn't help my issues, but they needed replacing anyway.
Next I pulled the carbs and gave them a cleaning. The float bowls were surprisingly clean, so I focused mainly on the pilot and main jets. Cleaned them up good, put the carbs back in, and she fired right up. The carb cleaning fixed the sluggish throttle response and reliance on the choke to keep running.
Here's a video I shot today after putting the carbs back in:
Now I've got another issue to work on. You can very clearly hear a clacking/rattling sound coming from the right side of the engine. The sound goes away after, maybe, 2000 RPM. I'm figuring its either a valve adjustment issue or, more likely, a cam chain adjustment issue.
Any comments?
Any comments?
1983 Kawasaki KZ550
- kaw-62046
28 Mar 2009 21:47 #276265
by kaw-62046
Replied by kaw-62046 on topic KZ550 Project - Need opinions
Sounds like it running on 3 cylinders,check the head pipes to see if all 4 are hot.Also sounds like some cam chain noise.
- PLUMMEN
- Thank you received: 104
28 Mar 2009 21:55 #276267
by PLUMMEN
Replied by PLUMMEN on topic KZ550 Project - Need opinions
definately sounds like a dead cylinder on the right pipe
- Mark Wing
- Thank you received: 22
28 Mar 2009 22:01 #276270
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic KZ550 Project - Need opinions
Dito.
Mark
Mark
Yorba Linda Cal.
- timebomb33
28 Mar 2009 22:02 #276271
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ550 Project - Need opinions
you still have a plugged pilot circuit not just a jet. the knocking sound will clear up after it fires and runs on all 4 and you do a carb sync.
- insignia100
28 Mar 2009 22:13 #276273
by insignia100
1983 Kawasaki KZ550
Replied by insignia100 on topic KZ550 Project - Need opinions
I was afraid the carbs were still the culprit. How would you recommend cleaning the pilot circuit? I actually tried to completely take the carbs apart, but the screws securing the throttle body (correct term? I dunno...) wouldn't budge. Perhaps spraying some carb cleaner into the pilot air intake (again, not sure if that's the correct terminology)?
I'm going to check the spark plug cables before I remove the carbs again to make sure that's not the problem.
1983 Kawasaki KZ550
- MFolks
- Thank you received: 540
28 Mar 2009 22:24 #276274
by MFolks
Replied by MFolks on topic KZ550 Project - Need opinions
The coils and the sparkplug caps all age with heat and time. I'd replace the sparkplug caps first and see if that helps. I think you can get new ones from z1 enterprises.
If you're lucky the sparkplug leads will unscrew from the coils, if not they may be one piece and have to change the coils all though NGK does make a sparkplug lead splice kit.
A can of the fuel additive "Seafoam" will help clean out the carbs. www.seafoamsales.com is their website. You can buy it at Wal Mart in the automotive chemical section,boating supply stores,and auto parts stores.
- insignia100
28 Mar 2009 22:34 #276285
by insignia100
1983 Kawasaki KZ550
Yea, I've actually got a can of Berrymans B12 that I had planned on using in a tank of gas once I got the bike running decently. My only concern is that, if fuel (or maybe air?) isn't getting through the pilot circuit, how will a fuel additive help?
1983 Kawasaki KZ550
- PLUMMEN
28 Mar 2009 22:44 #276288
by PLUMMEN
dump a can of seafoam in the tank with some new gas and take it out and run it hard around town a little bit(let it rev and stay in lower gears as much as possible)to let the carb cleaner do its thing,sometimes thats all it takes.in extreme cases sometimes you can cheat by holding your hand over the inlet side of carbs and cracking the throttle to blow them out also.
- MFolks
28 Mar 2009 22:47 #276290
by MFolks
Depending on how clogged it is a fuel cleaner like Berrymans or Seafoam will dissolve the varnish from old gasoline over time. You might have to drop the carbs and carefully dig out the blockage with some very fine stiff wire. I use a set of torch tip cleaners the welders use when the torches act up. I think you can buy them at a welding supply store.
