to shim or not to shim!
- kawboy13
28 Mar 2009 05:45 #276014
by kawboy13
to shim or not to shim! was created by kawboy13
It's almost riding time here in north central Ohio snd while I was checking over the bike ( 78 kz1000 ltd) I did the valve lash and found 3 with .04mm or less but the other 5 were .05mm. Should I replace these and take them to .10mm and let them wear back down to .05mm or leave them alone?
- grumpy56
- Thank you received: 6
28 Mar 2009 06:17 #276018
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic to shim or not to shim!
You are right at the minimum (or too tight), and according to the guys here, you should shoot for the top end (0.15mm on my 82 1000).
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Jeff.Saunders
28 Mar 2009 09:35 #276057
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic to shim or not to shim!
I always set my own bikes (with stock cams) around 4 thou (0.10MM). I never leave clearance at 2 thou or less (0.05MM). If you have to choose between 3 thou (0.075MM) or 5 thou (0.125mm), go wide...
I keep a mix of use and new shims handy to 'fine-tune' my clearances to get them all 4 intake and all 4 exhaust as close to one another in the set of 4 as possibly. It does make a difference...
I always measure each shim with a micrometer and write the actual readings on the shim with a Sharpie before I stash them in my shim box.
Z1 Ent on Facebook,
- loudhvx
- Thank you received: 1616
28 Mar 2009 11:46 #276091
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic to shim or not to shim!
Jeff.Saunders wrote:
Same here.
Same here.
1981 KZ550 D1 gpz.
Other links.
- bountyhunter
- Thank you received: 337
28 Mar 2009 12:14 - 28 Mar 2009 12:18 #276098
by bountyhunter
Replied by bountyhunter on topic to shim or not to shim!
ditto all the above: one or two thou wide is no problem, tight can mean a burned valve seat and destroyed head.
The spec on my engine is .002 - .004", I keep them .003" - .005". There is no performance difference I can see going a thou or two wider, but I don't have a dyno.
The gospel back when I built engines to race dinosaurs was that the exhaust valves were the most critical for a tight clearance because they got hotter than intake valves and so would expand and contract more due to temp change. Most of the engines I recall always specified a couple of thousandths wider gap for the exhaust, these days the specs seem to usually be the same (?)
Last edit: 28 Mar 2009 12:18 by bountyhunter.
- larrycavan
- Visitor
29 Mar 2009 07:47 #276329
by larrycavan
Replied by larrycavan on topic to shim or not to shim!
The cover is already off. The season isn't really started yet. May as well finish the job while you're this far along.
