???adjustable cam sprocket
- 77street
26 Mar 2009 12:48 #275555
by 77street
???adjustable cam sprocket was created by 77street
I run a gpz750 cam, is there anyone who makes an adjustable sprocket for these or only on aftermarket cams? I'm having a little flutter problem at idle. it runs fine but I can definitely feel it pushing out of the carbs, it completely clears up at about 2500rpms, from what I understand this could be shim height or cam timing, my shims are all set for .008-.012" is this to tight? or is it the timing.
- MFolks
- Thank you received: 540
26 Mar 2009 14:30 #275576
by MFolks
Replied by MFolks on topic ???adjustable cam sprocket
- KruZer
26 Mar 2009 18:43 #275659
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic ???adjustable cam sprocket
Adjustable cam sprockets will not fix a mechanical problem.
The sprockets are designed to move the power band, not fix problems...
Good luck,
Buzz
Good luck,
Buzz
