Stupid question, please help a dumb guy out!
- Pro_window78
26 Mar 2009 09:24 #275516
by Pro_window78
Stupid question, please help a dumb guy out! was created by Pro_window78
I just got a new points housing for my kz1000 78 model a2 (thanks buzz!!) Any way my question is regarding the seal. I assume it's the crank seal. I am seriously hoping it just pops on and I won't need to split the cases. Am I correct? Any expertise would be appreciated. - Ryan
- gane
- Thank you received: 1
26 Mar 2009 12:56 #275557
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Stupid question, please help a dumb guy out!
Ryan, seal in question is indeed, crank/points seal, no bigggie, simply installs from inside of points cover housing. I like to goop w/ assy lube, and make sure lip stays true to crank w/install.G
- Pro_window78
26 Mar 2009 12:58 #275558
by Pro_window78
Replied by Pro_window78 on topic Stupid question, please help a dumb guy out!
Thank you so much G!
- KruZer
26 Mar 2009 15:47 #275595
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic Stupid question, please help a dumb guy out!
Ryan,
You're welcome.
There is no seal on the crank or in the engine.
The seal in the cover keep the oil where it belongs.
The seal in the cover is pretty new and you shouldn't have to replace it.
Just take your old cover off, install a new gasket and install the new cover.
NOTE:
It looks like the gasket will fit either way but it won't. the gasket only goes on one way so be careful.
Buzz
You're welcome.
NOTE:
Buzz
- Pro_window78
26 Mar 2009 18:34 #275651
by Pro_window78
Crap, I didn't think about the gasket. I guess I better get a new one, or are those reuseable?
- KruZer
26 Mar 2009 18:51 #275662
by KruZer
Whether or not you can reuse the original gasket depends on the condition of the gasket and if comes off of the current housing without being damaged.
If the gasket comes off of the old housing in one piece and looks to be okay then put some sealer on it and use it again.
Make sure you notice how the original housing comes off of the bike and put the newer housing back on the same way.
The small slot on the housing goes on the bottom so the ignition leads can route out under the bottom of clutch housing.
Good luck,
Buzz
Good luck,
Buzz
- Thank you received: 2098
26 Mar 2009 19:01 #275668
by Patton
Replied by Patton on topic Stupid question, please help a dumb guy out!
- Pro_window78
28 Mar 2009 21:13 #276243
by Pro_window78
Thanks for all the help guys, this is an awesome site!! Btw, Will I need to drain the oil for this install? I just changed it and the filter so If so I want to maybe take a couple more rides on it and change it all on a rainy day. Thanks gentlemen! -Ryan
- timebomb33
- Thank you received: 10
28 Mar 2009 21:14 #276246
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Stupid question, please help a dumb guy out!
put it on the side stand and change away you should be able to do it with no oil gusing out.
- Pro_window78
28 Mar 2009 21:20 #276251
by Pro_window78
Nice, thats exactly what I was hoping you would say!
