- Thank you received: 2
Stripped Cam Cap Bolts - Time Sert Question
- KYKZ1100
25 Mar 2009 20:38 #275449
by KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
Stripped Cam Cap Bolts - Time Sert Question was created by KYKZ1100
I've read the prior threads on this and they refer to Time Serts. I'd like to try them but am not sure about the length of the insert. The threaded part of the cam cap bolt is about 19mm. Does the insert have to be that long? The 6mm Time Sert kit comes with 9.4mm inserts - would those be long enough?
If the 9.4mm inserts aren't long enough, does anyone know where I can order just a few inserts at a time? I haven't found anyplace online or locally to buy them individually or a few at a time. The vendor on eBay wants $20-30 for packs of 10.
1981 KZ1100A1 Shaft
2007 BMW R1200R
- MFolks
- Thank you received: 540
25 Mar 2009 21:23 #275455
by MFolks
Replied by MFolks on topic Stripped Cam Cap Bolts - Time Sert Question
My understanding of the Time Sert is that it telescopes under installation reducing the length to be able to grip the side of the hole(s) by swelling.
- 10Bucks
25 Mar 2009 21:59 #275459
by 10Bucks
Replied by 10Bucks on topic Stripped Cam Cap Bolts - Time Sert Question
Are you asking about Helicoil threadserts? I have Helicoiled entire heads and they work very well. The threadsert acually gets a little longer when it is threaded into the hole and then you punch the drive tang off and your bolt will thread completly through the insert. The hole is now threaded in stainless steel instead of aluminum. You will not likly ever have a problem with that hole again.
- MFolks
25 Mar 2009 22:20 #275462
by MFolks
The Time-Sert is something different than a Heli-Coil. Go to this website and check out the information:
www.timesert.com/
www.timesert.com/
- timebomb33
- Thank you received: 10
25 Mar 2009 22:23 #275464
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Stripped Cam Cap Bolts - Time Sert Question
the time sert is a much better product they are a solid insert so they wont mess up or pull out with repeated removal of the bolts like a heli-coil can.
- 10Bucks
25 Mar 2009 22:40 #275465
by 10Bucks
I looked at the link site. I see the Timesert is a solid threaded sleeve that is swaged into place when you install the bolt the first time. Interesting, probably better than a Helicoil and I have never had a failure in Beucoupe Helicoils.
Nonetheless to the original post, I would use this repair in a minute as you will end up with much more durable threads than the original tapped cast aluminum.
- Thank you received: 797
26 Mar 2009 08:28 #275501
by 531blackbanshee
Replied by 531blackbanshee on topic Stripped Cam Cap Bolts - Time Sert Question
a bolt needs to be screwed in at least as far as the cross section of the shank,a little bit more wont hurt.a lot more won't help because the cross section is what determines the strength of the bolt.hth
leon holmes
leon holmes
- shighley
27 Mar 2009 06:25 #275753
by shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
Replied by shighley on topic Stripped Cam Cap Bolts - Time Sert Question
Go with the Time-Sert. Ignore the threaded length of the bolt! What is important is the depth of the threaded hole in the head. The last step in installing a time sert is to run a lubricated "form" tap into the hole. This tap is included in the kit and it serves two functions. It acts as an driving tool and also swells the last thread in the insert out against the oversize threads cut into the damaged hole. As for "where to buy", TimeSert's site should have a distributors listing for your area. The length you ststed is plenty for the application, just make sure you have enough hole to allow the form tap to go through it. Again, their website shows installation requirements, if memory serves. If your handy with hand tools you will love this repair system. (I don't work for TimeSert) Ride safe, Steve
- KYKZ1100
31 Mar 2009 22:10 #277266
by KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
Replied by KYKZ1100 on topic Stripped Cam Cap Bolts - Time Sert Question
Thanks, Fastenal is listed as a distributor but I had to call three branches before I found one that would admit it. I ordered the M6 kit and some additional 12mm and 17mm inserts. I can't wait to get the head put back together.
1981 KZ1100A1 Shaft
2007 BMW R1200R
