- Thank you received: 28
Cam/timing chain breakage?
- TeK9iNe
- What did you do!?!
25 Mar 2009 07:38 #275230
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Cam/timing chain breakage? was created by TeK9iNe
Hi all...
Got my engine all in pieces and when I pulled out the cam/timing chain and had a good look at it, it had links missing out of it all over the place!
Its a hyvo style chain where theres 5 links sandwiched together per section. 5 of the middle links and 1 of the outside links where just randomly gone! :blink:
Me thinks I should be thanking the KZ gods for it not breaking whilst in motion!
My question is... what would cause this random breakage?
Age?
Wear damage?
The teeth on all the cam/crank gears look fine!?!
Whaa? :ohmy:
Age?
Wear damage?
Whaa? :ohmy:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- timebomb33
- Thank you received: 10
25 Mar 2009 07:57 #275236
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cam/timing chain breakage?
loose tensioners ,tight tensioners, age, very hard deceleration,poor chain quality, worn tensioners the reasons are many and varied and that is one of the main reasons when i split the cases on a motor i always replace the cam chain with out fail they take a pounding and they are cheap to replace compared to a new engine very cheap insurance.
