- Thank you received: 337
Valve Seals: How Do They Work?
- bountyhunter
Valve stem seals are not actually "seals" because they have to allow some oil flow down to lube the valve shaft in the guide. How are they designed to "leak" the proper mount of oil? As far as I can see, they have a tight fit on the valve stem. I don't see any hole or groove to seep oil. There is just the rubber ring with the spring around it for tension.
Do all valve seals leak a controlled amount of oil?
Is it normal to have some oil seepage down into the combustion chamber (from the valve guide through an open valve) after the engine is turned off?
I would like to understand how the seals are designed to work.
- keith1
- Thank you received: 2
- MFolks
- Thank you received: 540
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
at least for the intakes.
The tolerances are made to take all expansion into account so there's no stem-to-guide seizure and also the fact that there's no lubrication.
I just overhauled a brand H tiddler and the valve stems both looked great....but they were worn below spec. The intake had a seal but no seal is fitted to the exhaust because none
is needed, apparently. The guides were still within spec...barely.
So....new valves and new seal on the intake and away she goes.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- KruZer
It use to be tetraethyl lead that turned into lead oxide as it burned. The layer of lead oxide, would cover the valves and the combustion chamber. The valves hit hard against the valve seats several thousand times each minute. The lead oxide acted as a cushioning agent, and protects the valve and the valve seats. The lead oxide was also a lubricating agent. This reduced wear in the valve guides, as the valves slide inside them.
Now there are other additivies in gasoline that act as lubricating and cushioning agents for the valves, seats and guides.
Or so I've been told.
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- KruZer
Buzz
- bountyhunter
I was trying to figure out what is the typical "failure mode" for the seals. I have the four old seals (and old valves) from before the last rebuild and three of the four seals still feel pliable and tight on the valve stems... yet, they were all leaking oil like a real sob. I had one seal that was torn at the top so it was REALLY dumping oil, but the others were also leaking down into the combustion chamber and they don't look like they should have leaked.
- bountyhunter
That's what the machinist who did my head also said. I bought a new set of guides since the engine had 75k miles, and he showed me that all the original guides were as tight as the new ones so they didn't need changing. He said the guides only wear if the valves are set up wrong and they are putting a side torque on the guide.Right T_Dub and in the case of the KZ engine there's very little side loading on the valve stem because there are no rocker arms to push the valve against the guide. The DOHC design with the cam followers directly under the cam pushes the valve straight down.
Buzz
