- Thank you received: 337
Starter Clutch: Is This a Symptom?
- bountyhunter
24 Mar 2009 14:52 #274955
by bountyhunter
Starter Clutch: Is This a Symptom? was created by bountyhunter
All the talk about how bad the old 750 twin starter clutches are has me paranoid. Mine seems to work OK, it engages and releases.... but lately, I have noticed something that has happened twice so far that I know of. While idling, I hear a quick "clack" and feel a twitch through the handlebars. It is a metal-metal sound.
The clack sounds like the same clack I hear if the engine "kicks back" during starting and smacks the starter clutch, so I was wondering if this occasional sound is a symptom of a bad starter clutch?
I know that inertia keeps the rollers back so at idle they might wander over and get in the wronfg place if they were going to do that.
I can't think of anything else that would be doing it.
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
24 Mar 2009 18:43 - 24 Mar 2009 18:44 #275053
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Starter Clutch: Is This a Symptom?
If your starter clutch is behind the flywheel (and I am certainly NO expert on the 750 twin) I'd pull the flywheel and check everything out just for laughs. Might just save yourself a bundle.
Another thought....has the cam chain tensioner been looked at/adjusted lately ?? If not, then it might just be a good idea to check it out as well. If it's a manual one then adjust it. If it's a Mark I or Mark II automatic tensioner and you haven't had it apart for quite awhile then EITHER type needs looking at by now. Both are piss-poor designs
...the Achilles heel of the early Kwak four stokes.
Unfortunately they didn't get it really right until the water cooled 900s and 600s came out.
Last edit: 24 Mar 2009 18:44 by H2RICK.
- bountyhunter
24 Mar 2009 19:10 #275066
by bountyhunter
Replied by bountyhunter on topic Starter Clutch: Is This a Symptom?
Cam chain tensioner is mnual and it seems to be adjusted OK.
The starter clutch is behind the flywheel and a royal pain to take off.
