- Thank you received: 1
Cam Tensioner Installation Question - Rubber Guide
- HerrDeacon
Any help would be greatly appreciated as I was hoping to get the head on tonight and everything timed.
Also, do you use some kind of adhesive to stick these on?
- OnkelB
- Thank you received: 80
As for adhesive, that is only used to prevent the rubber dampers from falling into the cam chain cavity during assembly - I usually use a drop of super glue under each damper.
77 KZ 650 B1, 82 GPz 1100 B2.
- HerrDeacon
But why are they angled? What is the benefit of having them angled? Depending on what side you put them on the angle is facing a different direction (i.e. front vs. back).
Also, did you glue them to the head or to the shaft of the roller?
I have to say I'm worried about losing them down in the innards.
- keith1
- Thank you received: 2
Thanks Onkel.
glue em to the flat part on shaft after you put roller or sprocket on....i used superglue and ya got about 1 sec before its where its gonna be...try to get em where ya want them when they make contact...
- keith1
- RonKZ650
- Thank you received: 240
- keith1
Are you using new Kawasaki rubber? I just looked at a new one out in the garage and mines a perfect rectangle pillow shape. No angles to it. Maybe aftermarket parts coming into the picture here.
good point.....all sides should be flat....herrdeacon, got a pic?
- HerrDeacon
They were sort of shaped like wedges. The way the fit in, they caused the flat part of the shaft to not be level. I don't think it is a big deal as it won't impact the movement of the tensioner, but I did find it weird.
Thanks for your help guys.
