oil type
- chevyhead
24 Mar 2009 06:17 #274795
by chevyhead
oil type was created by chevyhead
- T_Dub
- Thank you received: 25
24 Mar 2009 06:37 #274797
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic oil type
Just maaaake sure its motorcycle oil. Car oil no dice, it has crap in it that your wet clutch wont like too much.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- chevyhead
24 Mar 2009 06:41 #274798
by chevyhead
Replied by chevyhead on topic oil type
ok thanks for the info. i just didn't know if with it having that high of milage if i should use a certain type?
- JMKZHI
- Thank you received: 48
24 Mar 2009 07:23 #274806
by JMKZHI
Replied by JMKZHI on topic oil type
You don't have to use a motorcycle specific oil.
Shell Rotella-T 15W-40 would be a good choice - it's a heavy duty oil having a fair amount of ZDDP which is a Zinc-Phosphate additive. The phosphate in ZDDP is a metal-to-metal protector. Some manufacturers list the amount of zinc-phosphate in the MSDS for the particular product.
Motorcycle specific & Racing oils have more ZDDP than car oils.
I don't know if they have more (or significantly more) than the Rotella-T or similar oils marketed for use in diesel engines, such as Cheveron Delo.
Avoid oils that have Energy Conserving on the API service seal - those have friction modifier additives that supposedly make the oil too slippery for the clutch; I'm not sure if any 10W-40 or heavier oils have the designation. The Energy Conserving oils have less ZDDP. Most (all?) car oils have less zinc-phosphate than they did 4-5 years ago.
- Thank you received: 2829
24 Mar 2009 07:27 #274807
by 650ed
Replied by 650ed on topic oil type
- anarki650
- Thank you received: 5
24 Mar 2009 07:27 #274808
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic oil type
+1 on all the advice given. +2 for using Rotella. I used to use bike specific oil, I was running BelRay synthetic that was hitting me like $7 a quart or something stupid like that. Once I heard about Rotella being good in these old air cooled motors I checked it out. $10 for a gallon at WalMart and both my bikes love it.
09 Kawasaki ER6n
Omaha NE
- chevyhead
24 Mar 2009 07:41 #274813
by chevyhead
ok well thank you. i had read the aticle on this a little bit ago about how they have reduced the amount of zinc so thanks for explaining it a little better for me.
- RonKZ650
- Thank you received: 240
24 Mar 2009 10:15 #274870
by RonKZ650
Replied by RonKZ650 on topic oil type
Shell Rotella 15w40 works fine, but it has to be upwards of 40 degrees out or too thick to start. Pretty much every 10w30,10w40, 20w50 designed for cars is now energy conserving so instant death for a wet clutch:laugh: Although not recommended by the masses, being bad for a wet clutch is a really broad thing. Not all wet clutches are the same, one motorcycle may have a marginal clutch to begin with and energy conserving could send it over the edge. I've found in my riding style and with my Kawasaki's at least energy conserving does not hurt a thing. I've run it in the winter months for several years. I'm going to switch to 10w30 Rotella next winter that is not energy conserving, but very hard to find.
- T_Dub
24 Mar 2009 10:24 #274873
by T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
I thought car oils being bad ahd something to do with more detergents as well?
I use Castrol 10W40 4-Stroke Motorcycle oil in my bike, does the job beautifully, and no worries about having the wrong oil.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
