kerker exhaust mounting 81 kz750 ltd
  • wireman
  • wireman's Avatar
Re: kerker exhaust mounting 81 kz750 ltd
21 May 2011 03:48
#452524
the pipe and collars get installed as a unit B)
the split collars wrap around the pipe in same direction you have them ,use rubber bands to hold them on the pipe when you install it.
  • jordash
  • jordash's Avatar
22 May 2011 04:13
#452704
:laugh: Citizens of tomorrow, it looks like the attached image.
Thanks wireman! I've got her back together, though leaking like mad. Still need to order some new gaskets. At least the paint job worked!
'08 KLR650
'82 KZ(Z)750 Spectre
In Denver, CO - Seeking nomad's land
  • dynastydudge
  • dynastydudge's Avatar
22 May 2011 17:06
#452823
those pipes fit up inside the motor? i bought the vance and hines, i havnt installed them yet, still working on the motor, but i did hold up the header to thee exhaust holes. and they arnt going inside the motor unless i grind off the flanges on the header. should they just butt up to it, or fit inside the motor some?
were not here for a long time, just a good time......1980 kz750 ltd h1
1982 honda cm 450e
  • jordash
  • jordash's Avatar
23 May 2011 17:58
#453060
dynasty- if you look at the photo I attached earlier, IMG_03471.JPG you'll see I have the two collars stuck inside, they are pressing against the copper gasket there. Doing it the correct way, the actual pipe should press against those gaskets, which are recessed in about 1 1/2".
'08 KLR650
