Gpz motor tranny and standard?
  • ran429
  • ran429's Avatar Topic Author
  • Master of FREE rides!
01 Mar 2006 18:03
#27393
I was wondering, my 550 Gpz had a 6 speed, my 750 has a 5.
Are they interchangable? I think its weird everytime I shift to 6th and its not there.
I dont mean a 550 tranny, i mean Gpz 750's also have 6 gears right?
Post edited by: ran429, at: 2006/03/01 21:04
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Gpz motor tranny and standard?
02 Mar 2006 03:14
#27481
Well, I can't speak for the later GPz's, but the 1982 (Z750R1) and the 1983 (ZX750A1) models are 5 speed.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JR
  • JR's Avatar
02 Mar 2006 04:22
#27484
Is there anything stamped on the case where the gear change lever enters ? Mine has a little box which shows
5
4
3
2
0
1
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
  • Snakebyte
  • Snakebyte's Avatar
02 Mar 2006 04:48
#27486
I believe all the gpz are 6 speed with same gearing. There was a Thread not too long ago on someone doing a six speed swap into a 650, but something with the kickstart prevented it. The six speed dropped into the750.
  • steell
  • steell's Avatar
02 Mar 2006 04:56
#27489
The 550's were 6 speed, the 750's were 5 speed.
I'm in the middle of installing a GPz550 six speed transmission in an 83 GPz750 motor right now, should be done in a day or two.
Post edited by: steell, at: 2006/03/02 16:37
  • apeman
  • apeman's Avatar
02 Mar 2006 10:17
#27556
I am sure there is an old thread or two in the archive on this topic. Steell: give us the details on your six speed swap. Inquiring minds want to know if this makes sense to consider for our 750s.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • ran429
02 Mar 2006 11:29
#27568
steell wrote:
The 550's were 6 speed, the 75's were 5 speed.
Well, let me know how it ends up on final test please? I am really interested in the outcome.
  • steell
  • steell's Avatar
02 Mar 2006 13:47
#27608
It's not my motor, I'm doing it for another guy (a member here), IIRC first gear is geared just a little lower and high gear (6th) is geared just a little higher in the six speed transmissions vs the five speeds.
The 83-85 GPz750 is just a little peaky, the power comes in at higher rpm, so the idea is to get another gear in there to keep the motor in it's powerband.
This one has a shaved head and an 810 kit, so it ought to run pretty good, unfortunately it's not mine :(
Post edited by: steell, at: 2006/03/02 16:49
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
02 Mar 2006 18:28
#27674
is it just a drop in modd or is there alot of modifications going on? what about the shifting forks/drum? what parts are needed for this?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • steell
  • steell's Avatar
02 Mar 2006 18:50
#27688
You need both transmission shafts with all the gears, the shifting drum and all three shift forks from the 550 six speed trans. I can assure you that even though the 750 and 550 shift forks look almost identical, they "will not" interchange. This motor was dropped off here dismantled and in a box (and anyone that builds motors knows what that's like) and the trans parts were mixed together. Good thing I enjoy a good challenge :laugh:
No mods needed in a GPz750, and I believe the KZ750 bottom end is identical, so it should be a drop in operation for the KZ750 models as well. I don't know if it would work in a kickstart 650 though, I have not tried it. Oh yeah, when installing it in a 83-85 GPz750 motor, a stock GPz750 offset sprocket is still required.
Post edited by: steell, at: 2006/03/03 08:36
  • Snakebyte
03 Mar 2006 02:16
#27778
Thank you for clearing that up for me steel.
