Vacuum switch valve hose
- zubley
19 Mar 2009 16:01 #273518
by zubley
Vacuum switch valve hose was created by zubley
I'm installing pod filters on my 1983 kz1100 ltd. What do I do with air hose that went into the air box? Or can I remove all of vacuum switch valve system? If so how do I remove it.
- Bluemeanie
- Thank you received: 14
20 Mar 2009 05:50 #273662
by Bluemeanie
Replied by Bluemeanie on topic Vacuum switch valve hose
Remove all hoses including valve. Run a hose from nipple to nipple where the valve was on the front valve cover. Plug off any vacuum sources used and that's about it! All of us have pretty much removed this system.
