Wont start up
- DeftoneKZ440
- RomSpaceKnight
- Thank you received: 2
- DeftoneKZ440
- wiredgeorge
- RomSpaceKnight
Put fresh gas in. Put new plugs in. Drain float bowls and remove, check for gummy stuff. Check for cracked intake manifolds before and after carbs. After more so.
- DeftoneKZ440
- Maverick
- Thank you received: 1
Good luck!
Maverick
1981 KZ1000M1
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- NOS
did you cross a plug wire?
I agree, it sounds like you may have crossed a plug wire. I don't know for your bike, but my KZ550 has one coil for #1 and #4 cylinder and the other for #2 and #3.
I wish you well, and hope you get it running soon
- steell
- ran429
- Master of FREE rides!
It was doing the same thing.
- steell
Primary or secondary side? Did you switch the wires going from the ignitor to the coils, switch the positive and negative wires, or have the plug wires on the wrong plugs?When I put the wiring back on my bike last week (without a diagram) I wired the coils backwards.
The KZ440 is a twin and fires both plugs at the same time, so you can't really put the plug wires on the wrong plugs.
I'm a little unclear on the symptoms, does the motor spin over using the electric starter? Does it start spinning over and then come to a sudden halt and backfire? If that's the case, then check the timing advancer under the round cover on the right side engine cover towards the front. Grab hold of the rotor and see if it turns clockwise. If it don't turn, then it's probably stuck, and probably in the advanced position.
Post edited by: steell, at: 2006/03/03 14:08
