- Thank you received: 8
Piston Pin Removal
- DoubleDub
- Visitor
17 Mar 2009 11:12 - 17 Mar 2009 11:13 #272754
by DoubleDub
Piston Pin Removal was created by DoubleDub
First time removing pistons - I heated up the cylinder with the small butane torch (per the Clymer) but the pins don't seem to want to budge. I definitely do not want to do this wrong. Just wanted to verify the correct/best way to remove the piston pin. Appreciate all the help!
Last edit: 17 Mar 2009 11:13 by DoubleDub. Reason: (spelling)
- DoubleDub
- Visitor
17 Mar 2009 11:14 #272755
by DoubleDub
Replied by DoubleDub on topic Piston Pin Removal
Found this:
www.z1enterprises.com/detail.aspx?ID=2158
The Clymer makes it sound like it should be simple without the tool, though.
- mariozappa
17 Mar 2009 12:04 #272763
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Piston Pin Removal
Did you take the circlips out?
1977 KZ650C1
- DoubleDub
- Visitor
17 Mar 2009 12:11 #272765
by DoubleDub
Doh!
Total noob mistake here...
Thanks for taking the time!
- mariozappa
17 Mar 2009 12:19 #272770
by mariozappa
1977 KZ650C1
take em out and take a socket the size of the pin and gently tap it out. ymmv
1977 KZ650C1
- DoubleDub
- Visitor
17 Mar 2009 12:21 #272773
by DoubleDub
Thanks again - I remember seeing them. I was pretty hesitant not wanting to destroy anything, but I didn't see them mentioned in the Clymer and haven't ever gotten this deep in an engine before. I'll give it a try!
- DoubleDub
- Visitor
17 Mar 2009 18:50 #272856
by DoubleDub
Thanks - that was exactly what I needed! Got all but one off without having to heat it.
