ring compresser
- Buda
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Old Man Rock
- Thank you received: 225
Hell I took mine off (cylinder) and placed back on several times during the course of my engine build (due to MRE once again ) for the cylinder decking was milled more than promoted/disclosed....
So install, found the problem, remove & installed measuing decking, removed for dual base gaskets, installed & remeasured, continue... After a while, not a biggy, a little time and patience insuring rings are in the correct orientation, a little at a time and they pop into place... After a few times you'll be accomplishing like a pro...
Oh yeah, through in afew F bombs as well but that doesn't add any time to the process..... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Old Man Rock
Remove the rings and go with bigger pistons to compensate, no need to worry about it then... :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
i always do it by hand i start with the center two and when they are in all the way i go to the outside i use a pair of bamboo chopsticks to manipulate the rings DONT ever use screw drivers or any thing metal as it can nick the rings.also i have a rod holder that i built out of 1/2" alluminium. it is the width of the studs in side and it suports the piston while your putting the block on.
i had a guy at work make the piston holders they show in the manual.....they seemed to be about 2" too short......
- Buda
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- timebomb33
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
