KZ750 shim under bucket into 77 KZ1000 for Big Cam
- addycml
16 Mar 2009 18:24 #272526
by addycml
KZ750 shim under bucket into 77 KZ1000 for Big Cam was created by addycml
Anyone can help me that question? Can I use the set of shim under bucket from 1980-81 KZ750 into my 1977 KZ1000 for a high lift cam with 0.430 lift?
- timebomb33
- Thank you received: 10
16 Mar 2009 21:41 #272622
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ750 shim under bucket into 77 KZ1000 for Big Cam
it is not a great idea to use the 650 or 750 buckets on big lift cams with heavy valve springs as they can actually break i have seen it happen that being said i have used them myself before on street motors and got away with it but motors cost so much nowadays i don't think i would trust them myself any more
- martijn
17 Mar 2009 14:05 #272792
by martijn
Replied by martijn on topic KZ750 shim under bucket into 77 KZ1000 for Big Cam
yes you can. 0.430 is not so heavy...
but you need different springs because of the more compression
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
19 Mar 2009 19:35 #273580
by kzz1p
Replied by kzz1p on topic KZ750 shim under bucket into 77 KZ1000 for Big Cam
Yes you can. I will caution you about using old used buckets with wear patterns. They can wreck a new set of cams. The cams and buckets transfer the wear patterns to each other. All cam companies will tell you to use new buckets with new cams.
- APE Jay
- Banned
- Thank you received: 58
19 Mar 2009 22:38 #273632
by APE Jay
Replied by APE Jay on topic KZ750 shim under bucket into 77 KZ1000 for Big
They fit, but were known to wear rapidly if valve spring pressure was increase over stock
- martijn
21 Mar 2009 14:26 #273957
by martijn
What do the after market springs do from APE? Are they tougher then stock or just thinner to let the spring being more compressed??
- APE Jay
- Banned
21 Mar 2009 16:00 #273976
by APE Jay
They both have more pressure and stack shorter to accommodate more lift.
Jay
Jay
