- Thank you received: 4
Snake Oil? Anyone ever use this?
- Vter Bob
16 Mar 2009 15:47 #272450
by Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Snake Oil? Anyone ever use this? was created by Vter Bob
I wasn't sure if I should put this in here or "Bike Related" If it doesn't belong here, please move it.
www.seized-engine.com/
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- timebomb33
- Thank you received: 10
16 Mar 2009 15:55 #272452
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Snake Oil? Anyone ever use this?
sure it will probably break the rings loose from the cylinders but you still will have a groove cut in to the cylinders from the rings rusting in place so you will need a bore job anyway.
- Russ Jackson
16 Mar 2009 16:02 #272456
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic Snake Oil? Anyone ever use this?
For 20 bucks where is the risk? Alot easier to break an engine down if it moves. I would try it. The ad says it works 80% of the time. I bet PB Blaster and Mystery Oil work about the same...Russ
- Thank you received: 2829
17 Mar 2009 06:50 #272691
by 650ed
Replied by 650ed on topic Snake Oil? Anyone ever use this?
The ad states: "Has your engine seized up?
Seized Engine.com has the solution!" Further down, however, it states: "Engine Release is the liquid solution for all types of engines that have seized up during storage."
I would think any lubricant (Blaster, Kroil, tranny fluid, etc.) would free up pistons/rings if that was the only problem. I suspect folks buy this miracle oil to try to free up engines that have seized when they ran low on oil at 80mph. I'm sure they're thrilled with the results. :laugh:
