bike assembly question
- Bicycle Lee
I know I sound like an idiot, so take it easy on me haha
1978 KZ1000 police
- Thank you received: 2098
If not already done, could also pull up the diagrams on kawasaki.com with bolt sizes often shown in the parts listing.
Good Luck!
And here's an example:
[Click on image to enlarge view]
REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
1 92007-031 BOLT,STEERG STEM HEA 1
2 92022-230 WASHER,STEERG STM HD 1
3 46100-003 WASHER,WAVE 1
4 92090-007 NUT STEERING STEM LC 1
5 46098-016 CAP, STEERING STEM 1
6 92047-011 CONE,STRNG STM BRNG 1
7 600A0800 BALL STEEL 1/4' 39
8 92048-006 RACE STRNG STEM BERN 1
9 92048-008 RACE,STRNG STM BRNG 1
10 32002-1010 FRAME 1
11 28012-016 REFLECTOR,REFLEX 2
12 92094-011 DAMPER RUBBER,REFLEC 2
13 92091-022 BOLT,ENGINE MOUNTING 1 L = 310 M/M
14 311B0800 NUT,8MM 2
15 461F0800 WASHER SPRING 8MM 8
16 32030-025 PLATE,ENG MOUNT FRON 1
17 92001-1397 BOLT-8X63 1
18 110G0859 BOLT,HEX HEAD,8X59 1
19 92019-021 NUT,LOCK,10MM 3
20 461F1000 WASHER SPRING 10MM 3
21 92001-1262 BOLT,HEX HEAD,12X55 1
22 115G0818 BOLT-SMALL-UPSET,8X1 2
23 32029-1014 PLATE,FT ENG MNT LWR 1
24 32030-066 PLATE,REAR ENGINE,L. 1
25 32030-067 PLATE,REAR ENGINE,R. 1
26 92001-1578 BOLT 3
27 92027-160 COLLAR,ENG MOUNTING 1 L = 31 M/M
28 92027-159 COLLAR,ENG MOUNTING 1 L = 52 M/M
29 92001-1577 BOLT,FLANGED,8X35 1
30 92003-099 BOLT,ENGINE MOUNTING 1 L = 165 M/M
31 92091-023 BOLT,ENGINE MOUNTING 1 L = 250 M/M
32 92001-1265 BOLT,HEX HEAD,12X70 1
33 461F1200 WASHER SPRING 12MM 2
34 92016-045 NUT,12MM 2
35 32049-101 BRACKET,SIDE COV,R.H 1
36 92037-134 CLAMP,OVER FLOW PIPE 1
- keith1
So I'm getting to the point where I'm almost ready to put my motor back in my bike and when I went to check all my labeled bags of bolts and what not I found that the marker I used to write on the bags had mostly worn off and now I'm worried I won't be able to remember where everything goes. I've been looking in my Clymer manual, but it isn't that much help. Is there any photo-tutorial online that anyone knows of that outlines what goes where?
that sucks....figures, you take care and bag and label thinking ahead, and ya get done in by a lousy marker....sounds like my luck....good luck, you ll get em back where they belong just gonna take a little longer......
- PLUMMEN
- Thank you received: 104
- Old Man Rock
- Thank you received: 225
Weld the motor into the frame and you won't have to worry about them bolts then... :ohmy: :huh: :dry: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- PLUMMEN
im not even going there! :ohmy: :huh: :dry: :blink: :S :woohoo: :laugh:I think all the bolts only fit in one way. If you have the wrong one in the wrong hole you will know it.
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- Bicycle Lee
If you grouped them in the bags to the item you were removing it could be easy to figure out. Why not post pictures of them and we can have a contest trying to figure out where they belong.
Sounds like a plan. I'm test firing the motor tomorrow (fingers and toes crossed), so by this time tomorrow I'll know if I need to bother knowing how to put the thing back in the frame or not.
Thanks to everyone who posted.
1978 KZ1000 police
