Oil cooler for 1100
- Darkangel
Oil cooler for 1100
14 Mar 2009 12:27
I would like to slap a oil cooler on my KZ1100. Does anyone have any Idea how that can be achieved.
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- MFolks
Re: Oil cooler for 1100
14 Mar 2009 15:15
www.americanclassix.com
sells fittings and
www.holley.com/index.asp?division=Earls
sells the Earls brand of competition plumbing oil coolers and SS lines.
- Darkangel
28 Aug 2009 22:12
at american classics it says the oil adapter there is for the 1100J model engines....I have a KZ 1100 A2, and I dont believe those model came with a J engine.
- Buda
28 Aug 2009 22:43
Im almost sure that you have a j. The way I understand it any 1000 or 1100 after 81 is a J.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- Mcdroid
- Gone Kwackers
29 Aug 2009 02:11
Buda wrote:
You may not have a 'J' model bike, but Tom is correct, you do have a 'J' style motor.
Tom
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- kzr750r1
29 Aug 2009 08:45
MFolks wrote:
Just remember when finding a mount location that nothing touches when the suspension is fully compressed.
I have mine (Stock Zephyr cooler with AN fittings attached) just millimeters below the lower triple tree when turned at full steering lockout. Just recently kissed the fender. Not enough to cause damage just provide a paint transfer.
The curved units may afford an opportunity to provide clearance of a large cooler. Also depending on your climate you could place a thermostat in line to keep the motor warm in the cold.
I had forgotten Earls have the oil coolers in a curved configuration these days. Could help with some fender clearance if the suspension stroke is completely used.www.americanclassix.com sells fittings and www.holley.com/index.asp?division=Earls sells the Earls brand of competition plumbing oil coolers and SS lines.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Darkangel
29 Aug 2009 12:36
I am thinking of using the stock ones off of a KZ550, or maybe a really small earls radiator.
- kano
- Not Another Bloody Limey!
- kzr750r1
29 Aug 2009 12:46
Darkangel wrote:
Those are pretty small aren't they?I am thinking of using the stock ones off of a KZ550, or maybe a really small earls radiator.
