81 kz550 ltd engine ?s
- KZ74361
12 Mar 2009 19:11 #271464
by KZ74361
81 kz550 ltd engine ?s was created by KZ74361
i just bought a 81 kz550 ltd for $100 its rough but is what i was wanting anyways the motor sounds like it has a knock at idle the more rpms you give it the more th knock goes away any ideas on what to check? Also if needed where could a rebuild kit be purchased?
- gane
- Thank you received: 1
12 Mar 2009 20:28 #271493
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic 81 kz550 ltd engine ?s
Kz, knocks are not good.start with the basics. all 4 pipes get hot. compression is roughly equal, valve clearances ok. carb sync close. oil pressure. in spec. 4's running on all 4 are seldom knockers. change oil and look for copper in oil/filter. a 100$ bike generally is just that, do what you can before tear down.luck g
- timebomb33
- Thank you received: 10
12 Mar 2009 20:44 #271500
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 81 kz550 ltd engine ?s
could be just because the carb's are out of sync or it could be your clutch basket or or or or or!!!!
- timebomb33
12 Mar 2009 20:46 #271501
by timebomb33
by the way the kz550 ltd is one of the best wheelie machines ever so if it isn't to bad make it work you'll have fun on the little bugger.
