KZ750 freeze up while riding
- row107
10 Mar 2009 17:20 #271002
by row107
KZ750 freeze up while riding was created by row107
Hey fellas,
I bought a 77 kz750b1 twin from a guy who claims that it froze while he was riding. My first thought was that he ran it out of oil but he said no. Its been sitting for a few months. I used the penetrating oil trick but no go. Im pretty sure that I have to take the engine apart. Any suggestions? I tried taking the top end off but it seems that the two sections adheized together. I tried prying, pulling, everything no go.Thanks, row107
- bountyhunter
- Thank you received: 337
10 Mar 2009 19:20 - 10 Mar 2009 19:21 #271058
by bountyhunter
Replied by bountyhunter on topic KZ750 freeze up while riding
I think the most likely culprit in a sieze would be either a main bearing cooked or a piston siezed in the cylinder. I think a starter clutch can do it if it fails just wrong.
The head should come off the cylinder pretty easily, but getting the cylinder loose from the crankcase can be a royal pain even in a good engine. There are pry points but it is still hard to separate. They used a very strong sealer on mine and it was murder to pull free.
Last edit: 10 Mar 2009 19:21 by bountyhunter.
- timebomb33
- Thank you received: 10
10 Mar 2009 19:27 #271065
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ750 freeze up while riding
double and triple check that all the bolts are out before doing anything else
- row107
10 Mar 2009 20:42 #271093
by row107
Replied by row107 on topic KZ750 freeze up while riding
Do you know what year engine are the same build incase I need one. A friend found a '82 twin.
- trianglelaguna
- Thank you received: 235
10 Mar 2009 22:09 #271106
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic KZ750 freeze up while riding
timebomb33 wrote:
a common thread answer is given above as to the head still being hard to lift off....
1976 KZ900
2003 ZX12R
2007 FZ1000
- row107
11 Mar 2009 11:24 #271182
by row107
I got the head off but the section that covers the crank will not budge. Where can I find a service manual either on cd or hard copy.
- MFolks
- Thank you received: 540
11 Mar 2009 12:30 #271187
by MFolks
Replied by MFolks on topic KZ750 freeze up while riding
Try at
www.repairmanual.com
it might be a few $ but has all the factory specs in it. Another place to look is
www.onlinefreebooks.net
- BSKZ650
- Thank you received: 14
11 Mar 2009 12:55 #271191
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic KZ750 freeze up while riding
sure does sound like a piston siezed in the cly, if you are looking down the bore is there any visable scratches or scoring?
