Torque motor, what's in there?
- shighley
I got to thinking how I actually ride and what I do with the bike and this thought floated to the top. Call me crazy for not wanting max HP. Any advice is sure welcome, thanks and ride safe, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- zoro
- Thank you received: 1
GHOSTRIDER,1980,KZ1000ST
- EricHa
www.flowbenchtech.com/porting/CRH/pricing.htm
www.flowbenchtech.com/porting/CRH/KZ_Str...ngine_Components.htm
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
1)What kind of money are you looking to spend?
2)What kind of fuel are you planning to use?
3)How often do you plan on working on it?
4)What is your skill level?
- mark1122
- Keep twisting it
- Thank you received: 109
Hi All; If a person built a Z1 engine for peak torque at mid RPM ranges, what would the components be? This motor would probably give up HP on the top, but would pull like a tractor in the 4K to 7K range. I'm guessing bigger is better, low compression, mild/stock cams, tiny carburetors and small diameter head pipes and a small collector.
I'm trying to solve this riddle too.
U have some things right some not so. Bigger is better ,depends on where its bigger.
More CC's and More Compression will raise torque. Smaller carbs will give u a stronger signal (read more throttle responce)than too big. Same with a pipe.Cams , more duration = less compresion (using the same pistons),and more top end.
Smaller ports will be more responsive at lower rpms than a port that is too big.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- PLUMMEN
- nads.com
- Thank you received: 20
Lobe centers please? See where alzheimers comes in. We just ask again. What was I talking about?that exact combination has been spelled out more times then i can remember,i figured anybody whos seen my z1 was from the last build would have it memorized!:laugh: 900 bottem end 1197 kit,mildly ported head with small valves 410ish cams 28-29 carbs stump pulling midrange stoplight to stoplight urban assualt bike.
- Thank you received: 2098
...We just ask again. What was I talking about?
Thank goodness I don't have that problem.
Knock on wood.
Is that somebody at the door?
- nads.com
- APE Jay
- Banned
- Thank you received: 58
It becomes a tractor motor and wants to rip your arms off. Riding it, it seem like it has a bunch more power when in fact it doesn't, but is a blast to ride.
