- Thank you received: 2
ball bearing.....where does it go?
- pburnhamb
08 Mar 2009 19:24 #270486
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
ball bearing.....where does it go? was created by pburnhamb
I have the engine out. head and jug off. pistons off. all side covers off. I took the 13 bolts on the top of the case off and tilted it up on its end, took all the oil pan bolts out,...started to take the oil filter/housing off and a ball bearing rolled from somewere onto the ground.
at first i though it rolled out of the filter housing, but only because that is that i was working on at the time. I dont know where it came from and i have changed the filter with the engine in the frame and have never seen it before.
i thought it might belong to the oil pressure relief valve, but i can see the ball in there.
It scares me.
anyone have any suggestions as to where its home might be?
It scares me.
1976 kz900
1977 xs650
- MFolks
- Thank you received: 540
08 Mar 2009 19:32 #270488
by MFolks
Replied by MFolks on topic ball bearing.....where does it go?
I'd ask Jeff Saunders at
www.z1entrprises.com
. On the bigger 1000's and 1100's a bearing was inside the cluch pusher assembly. Not sure about the smaller engines.
- gane
- Thank you received: 1
08 Mar 2009 19:38 #270491
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic ball bearing.....where does it go?
P, Que moto est? and dia of ball? the only free ball I'm familaiar w/is the one at the r/h end if cl. push rod. G
- Mark Wing
- Thank you received: 22
08 Mar 2009 19:52 #270495
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic ball bearing.....where does it go?
I bet it's from the clutch push rod too. Is the clutch removed? There's a ball bearing between the sort of mushroomed shaped thing that operates the clutch and the long rod the clutch cable moves if that makes sence.
Mark
Mark
Yorba Linda Cal.
- Thank you received: 2098
08 Mar 2009 20:53 #270507
by Patton
- pburnhamb
08 Mar 2009 21:24 #270512
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic ball bearing.....where does it go?
AHHHHH , i can sleep tonight. thank you guys. I do have the clutch off and there is no ball bearing in the shaft, so this little bugger must live there. there is one of these on a 650 right?
wish i could buy you all a a round of drinks!
thanks.
patrick.
thanks.
patrick.
1976 kz900
1977 xs650
- Mark Wing
08 Mar 2009 21:27 #270515
by Mark Wing
Yorba Linda Cal.
Yes the bearing is in 650's and it goes between #12 and #23
Yorba Linda Cal.
- timebomb33
- Thank you received: 10
09 Mar 2009 21:03 #270820
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ball bearing.....where does it go?
don't be stressing man, there is a spot for everything
