Head Gasket Replacement
- BIGD
08 Mar 2009 16:41 #270438
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Head Gasket Replacement was created by BIGD
I was hopeful that I could see if there were any tips to replacing my head gasket and if I should replace valve seals at the same time. I have my original manual that came with the bike. Thanks BIGD 1981 KZ1000 M1
- bountyhunter
- Thank you received: 337
08 Mar 2009 17:41 #270455
by bountyhunter
Replied by bountyhunter on topic Head Gasket Replacement
Valve seals go bad pretty regularly. I would change them for sure and lap the valves.
- BIGD
11 Mar 2009 13:08 #271196
by BIGD
Replied by BIGD on topic Head Gasket Replacement
Thank you. BIGD
