- Thank you received: 1
GPz1100B1/B2 cam specs
- Z1109R Fin
05 Mar 2009 04:50 - 05 Mar 2009 04:50 #269790
by Z1109R Fin
Z1000R ´83...Slightly modified...
GPz1100B1/B2 cam specs was created by Z1109R Fin
Howdy folks
Can´t find info of these cams. Need lift and duration so all cam gurus, help:blush:
Last edit: 05 Mar 2009 04:50 by Z1109R Fin.
- OnkelB
- Thank you received: 80
05 Mar 2009 05:02 #269791
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic GPz1100B1/B2 cam specs
Masa, I'm at work now but I have the specs at home - will post them in a couple of hours when I get off.
- Z1109R Fin
05 Mar 2009 05:27 #269797
by Z1109R Fin
Replied by Z1109R Fin on topic GPz1100B1/B2 cam specs
OnkelB wrote:
Tusen Tack, Bo! I thought you could have them, we discussed this subject some time last year here or on the other site but I couldnt find it. Thanx!!
- OnkelB
05 Mar 2009 07:36 #269806
by OnkelB
Here you go:
1981 KZ1100 B1 Gpz:
Intake:
Duration: 280 - Lift: 8,4 mm - Open: 35 BTDC - Close: 65 ABDC
Exhaust:
Duration: 280 - Lift 8,8 mm - Open: 68 BBDC - Close: 32 ATDC
I'm not 100% sure, but I think these cams are also used on KZ1000J/R1 models.
1982 KZ1100 B2 GPz:
Intake:
Duration: 288 - Lift: 8,8 mm - Open: 34 BTDC - Close 74 ABDC
Exhaust:
Duration: 288 - Lift: 8,8 mm - Open 72 BBDC - Close 36 ATDC
I believe these cams are also used on the KZ1000R2.
1981 KZ1100 B1 Gpz:
Intake:
Exhaust:
1982 KZ1100 B2 GPz:
Intake:
Exhaust:
- Z1109R Fin
05 Mar 2009 08:06 #269812
by Z1109R Fin
thanks Bo.i needed info for my R2. Jätte finnt!!!
- OnkelB
05 Mar 2009 08:15 #269813
by OnkelB
No problem, happy to help.
