Transmission Question
- rjd4949
28 Feb 2009 14:26 #268711
by rjd4949
"...all we need is a fast machine."
Transmission Question was created by rjd4949
My 79 SR650 doesn't upshift from stand-still - 1st & neutral only. Is that by design?
- Thank you received: 2829
28 Feb 2009 14:27 #268712
by 650ed
Replied by 650ed on topic Transmission Question
no
- donthekawguy
- Thank you received: 8
28 Feb 2009 14:42 #268717
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Transmission Question
Yes- you can't shift up at a stand still.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
28 Feb 2009 15:04 #268721
by 650ed
Sorry folks but the answer is still no. I can shift my KZ650C1 down to 1st, up to 2nd, 3rd, 4th, and 5th without even starting the engine. Always could since new. Ed
- RonKZ650
- Thank you received: 240
28 Feb 2009 18:17 #268767
by RonKZ650
Replied by RonKZ650 on topic Transmission Question
Ed, your transmission is broke since new :laugh: Actually both responses are correct. 1977 KZ650 did not have the neutral finder, 1978 up did. Well documented what the neutral finder is, it makes upshift from first to neutral at a standstill always go to neutral. The output shaft has to be spinning to access second gear on the 1978 up models. 1977 you can shift all the gears at standstill.
- PLUMMEN
- Thank you received: 104
28 Feb 2009 18:17 #268768
by PLUMMEN
Replied by PLUMMEN on topic Transmission Question
on 900-1000 rear wheel has to be spinning to get into 2nd gear,not sure about 650
28 Feb 2009 20:45 - 28 Feb 2009 21:04 #268818
by 650ed
RonKZ650 "1977 KZ650 did not have the neutral finder, 1978 up did."
Ron, Your post made me get off my butt and look in a manual for the 1978 KZ650. You're right, of course, beginning in 1978 the KZ650s have balls in the transmission that fall into grooves in the output shaft (ouch!) when it's not spinning and keep the trans from upshifting.
Geez, what other kind of complicated new fangled gadgets did they put on the new model KZ650s? Next thing you know, they'll be putting on fuel gages and removing the headlight on/off switches and kickstarters. Ed
Last edit: 28 Feb 2009 21:04 by 650ed.
- rjd4949
01 Mar 2009 07:18 #268897
by rjd4949
Replied by rjd4949 on topic Transmission Question
Thanks for the info, guys. This helps.
