- Thank you received: 1
Soda Blasting
- Pfaelzer
27 Feb 2009 14:07 #268514
by Pfaelzer
1977 KZ 1000
Queen Creek, Arizona
Soda Blasting was created by Pfaelzer
Does anybody has experience with soda blasting?
I need to clean my engine cases and was wondering if that would work.
1977 KZ 1000
- kawsakiman
- Thank you received: 6
27 Feb 2009 14:30 #268519
by kawsakiman
Replied by kawsakiman on topic Soda Blasting
- kawsakiman
27 Feb 2009 14:31 - 27 Feb 2009 14:34 #268520
by kawsakiman
little closer up showing how the cases look after boring them.
remember, that crap gets EVERYWHERE!
wash, wash and then one more time for good measure.
don't think you can blow out the bolt holes with compressed air.. run a tap through them. you'll be amazed how much gets in there.
after running a tap through all the holes, wash it one more time.
Last edit: 27 Feb 2009 14:34 by kawsakiman.
- Pfaelzer
27 Feb 2009 15:33 #268533
by Pfaelzer
1977 KZ 1000
Replied by Pfaelzer on topic Soda Blasting
that looks clean. Did you take the parts to a shop or did you buy the soda media and did it yourself?
1977 KZ 1000
- MFolks
- Thank you received: 540
27 Feb 2009 18:49 #268562
by MFolks
Replied by MFolks on topic Soda Blasting
The auto restoring crowd use it a lot as it's friendly to the environment and leaves little to no residue after blasting.
- otakar
27 Feb 2009 19:18 - 27 Feb 2009 19:19 #268570
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Soda Blasting
Soda blasting and walnut shell blasting are the two best way to clean Aluminum engine parts. These two media are totally safe for Aluminum engine parts. If by some chance you leave a little behind, they will not destroy the engine. We use these at work exclusively for this purpose. Some times, (more so than not we mix the two to get the best results.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 27 Feb 2009 19:19 by otakar.
- Pfaelzer
02 Mar 2009 11:15 #269240
by Pfaelzer
1977 KZ 1000
I just found out about "PitStopPerformance" in Florida. They clean engine cases and paint them with high temp. silver. The finish is supposed to look better than new.
Anybody done that or seen it done?
1977 KZ 1000
- donthekawguy
- Thank you received: 8
04 Mar 2009 00:50 #269536
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Soda Blasting
Pfaelzer wrote:
They sell rebuilt engines on ebay every now and then. They look great with the silver paint.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
