- Thank you received: 540
Baffle For My Kerker?
- MFolks
- Z1109R Fin
- Thank you received: 1
Russ, Looks like a 2" Competion Baffle to me. I would buy it from you if you want to sale it. If it comes out ok. PM me if you want to sale it and good luck.
Just got a 2" baffle for my Kerker from Z1. It looks a lot smaller than this one. I´d say it´s 2,5" but just measure it and let us know.
Z1000R ´83...Slightly modified...
- Old Man Rock
- Thank you received: 225
I'm sure there's numerous other ways but here's how I did mine.....
With the exhaust Megaphone (muffler pipe) disconnected from the header, first remove the bolt on the inside frame side of the Megaphone, towards the rear.
Then from the clamp end of the Megaphone, with a wood dowel or similar (1" square stock), tap out towards the rear...
NOTE: Even on a brand new exhaust, the stock baffle (with fiber wrapping) was in there fairly tight.
Same time, you'll find your baffle is most probably not wrapped as my 1.5" comp baffle was... basically a straight pipe welded to another pipe with holes in it, no wrapping....
NOTE 2: One thing I came across getting the new baffle in... The friggin Kerker emblem plate attachment pins...
They use those non screw type pivot pins.... Had to drill one of them out (inner most pin) to all the baffle to be inserted fully inside the Megaphone and use a screw once the baffle was in place...
May be where one of the hang ups is in your set up....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
... sure wish I had a stock set up that I could trade you.
That's Plan B. :lol:
Could also continuously soak for a day or three with PB-Blaster around the baffle exit area.
Important to be careful so as not to damage exterior appearance of can.
Could also try using dry ice on baffle (to shrink it) and simultaneously use heat gun on can (to expand it), all immediately before attempting to extract the baffle.
Good Luck!
- darmahsd
If you just want a Super Trapp end, this is what I did to another Kerker that I had on a Honda 750 many years ago.
I bought the discs and made an aluminum end plate. Use a disc as a pattern to make the end plate and to locate the holes at the flange around the baffle hole in your Kerker photo. Then, using the threaded inserts that you can get in a good hardware store, or the ones that use the blind rivet principle, apply them to the holes. Make sure they are the steel type and not aluminum. I don't remember if they were 1/4 inch American thread or 6 or 7 MM. Then, get long allen head stainless steel screws and make sure that you use anti-seize and now you have some adjustment to the sound, if you don't mind a little phft phft noise that is characteristic of the Super Trapp discs.
Stephen
- trianglelaguna
- Thank you received: 235
anyways i need an emblem for a kerker,,,dynoman?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Mcdroid
- Gone Kwackers
- Thank you received: 317
bumping up this old thread...did Russ sell his bike??no visits since july?
It used to be, if you emailed the Kerker people at Supertrapp and were properly explanatory and nice about it...they would send you, for free, emblems. I received two that way several years ago.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
...It used to be, if you emailed the Kerker people at Supertrapp and were properly explanatory and nice about it...they would send you, for free, emblems....
Should maybe ask Amy to handle this. :lol: :lol: :lol:
- hal0tw0
- Thank you received: 4
1976 KA900. VM28 pumper carbs, K&N pod fiters, RC performace 4/1 exhaust, Dyna ignition, Accel coils and wires, Ohlins rear shocks.....more to come
- trianglelaguna
It took very little convincing with the man i spoke with "Bruce" @ supertrapp, i did mention
that i support them with a supertrapp on my 900 and a kerker on two other bikes...
where do you want me to mail the brand new emblem was all he asked.......free
Thumbs up to supertrapp exhuasts for being the real deal... and another reason to buy from Supertrapp/owner of Kerker now also......10outta10
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
I sent a great big thank you letter and a note with a pic of my vintage Supertrap all shiny on the 900......
and today i got a cool note asking if i would mind if they used the pic in their gallery....awesome
next the MKII in blue with the vintage Kerker sporting the new emblem........
Cool Company...rare these days.....
they even stuck the picture in "sportbikes" instead of the universal section....nice touch....
www.supertrapp.com/gallery/gallery.asp?CatID=3
1976 KZ900
2003 ZX12R
2007 FZ1000
- Mcdroid
- Gone Kwackers
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
