- Thank you received: 109
Header length
- mark1122
- Keep twisting it
I have only 1 reply to that.
:laugh: :laugh: :laugh: :woohoo: :silly: :lol: :laugh:
That was hilarious man. are u in the right business?
I don’t know what u do for a living but i think u should be in entertainment.
By the way , i see u posted at 3:30 am. What the hell are u doing? are u feeding the friggin gremlins?
Thanks for making my day.
Kzz1p.
I think I will start with the 108 lobe centers that are recommended .
I can use davel’s recommended roll on time test, to get a base line. Then I can adjust to 106, 110 and try that.
I wish I could try some dif pipes ,my friend has a couple. But they wont fit without modification due to my wider swing arm.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- martijn
- mark1122
- Keep twisting it
I'm running a 1200cc with 0.395 webs at 104,5 and 108 LC's. Still standard 28vm's and it has the best torque I ever had. This set up is BIG fun in the mountains. It still runs 10.500 rpm but not so fast when lobes set at 106-108. Nver had reversion troubles.. only a bit pinging because of the high compression (180 psi cold) so I swop to BS34, see what happens
What is the duration? what was the recomended LC for the cams?
Do u have any head porting done?
You could advance the timeing a bit (start the spark sooner) to try to avoid the ping . What is it set at now? Dana S? stock?
Or you could try a little more overlap on the cams.
Just a thought.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- joe k
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
kzz1p wrote:
I would like to see someone post the RC400 definition as listed out of a "RC Engineering catalog" (as per Russ Collins)
I would like to see a copy of that catalog page. Does anyone out there have a Catalog????????????
here you go :laugh:
Thank You Joe! I knew the RC400's were bigger then we were talking about. They have the 310* duration, that is very big for a street bike and most bracket racing bikes.
- kzz1p
davel wrote:
davel wrote:[/
I disagree. Look at duration at 0.030 lift for the following
Web 0.365 lift – duration 262 (This is what I’m running)
APE 0.410 lift – duration 266
APE 0.435 lift – duration 266 (Marks cam)
That cam should provide loads of mid range in a 1200 or 1300cc motor if set up properly. Pulling 5th gear at 3000RPM should be no problem. In fact, it should be scary.
I disagree! By looking at the RC page that Joe k has posted for us. Those RC400's are called "Pro Stock Special" that means very high compression, for very high RPM. When it says hot street I don't think they were talking about everyday riding. Yes people do use them on the street, I have always called them boat achors. I can personally think of better street cams with more useability that would put Marks motor through the roof. Those cams are so big they couldn't pull a sick whore off a toilet at 3,000 rpm's. Back when the 400's came out, everything was based on car technology with fat durations and fat overlap. If you look at most cam catalogs now days, you won't see any pro stock cams with that big of duration or 90* of overlap. You can set them up until the cows come home, but you can't make a silk purse out of a sows ear. Just in case you havn't noticed, the 400's aren't even close to the APE 435's.
- mark1122
- Keep twisting it
they have 260* of duration and about .424" lift.
@ .050" lift and 108* L/C has a timing of 22*-58* / 58*-22* (44* overlap)
APE 0.435 lift – duration 266 *** @ .030" so it will be less.
APE 0.410 lift – duration 266 ***@.030"
Davel's
@ ? lift?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- nads.com
- Thank you received: 20
- nads.com
- kzz1p
U cant go by those #'s. they are taken at a very low lift for sales purposes.
Yes sales numbers are trickie and yes advertised duration and lift are trickie for sales purposes. I will give you that. Being as dumb as I am, I would ask the question: If the RC way was the hot ticket, why didn't everyone copy it?
Why didn't everyone just add alittle more lift and duration to build a bigger and better mouse trap? It looks like everyone else ran the other direction. They went to smaller durations,higher lift and smaller overlap and some went to dual pattern.
Mark it's your bike, you have to ride it. I am just a friend that is saying, hey! theres a better way. I don't give advise, no one ever takes it. I am only trying to advice you.
- mark1122
- Keep twisting it
It gets the cam past the ramp so it is more accurate. There is just too little of movement on the ramp to tell when it starts to open.
Most cam grinders use .040" which is 1mm. but when u read all the dif sales lit. they use smaller lifts to make the cams appear to have more duration than there competitors.
the problem is when u try to compare 2 cam specs that were derived using dif lift point.
I will try using e .030" just to get a comparison #.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- davel
My mistake on the cams. I thought mark was running the APE K435s
