torque specs
- Bicycle Lee
torque specs
21 Feb 2009 11:40
So I am putting my engine back together and in the manual it doesn't show torque specs for certain things like the clutch cover, ignition cover and stator cover, etc. Is it safe to say you don't have to torque them to a certain tightness?
1978 KZ1000 police
- trianglelaguna
Re: torque specs
21 Feb 2009 11:49
easygood/ hand tight/ and a re-check after riding is fine...you get em too tight and they get even tighter over time...then you can have a hard time getting em back out without an inpact wrench later...my 2 cents
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Mcdroid
- Gone Kwackers
Re: torque specs
21 Feb 2009 11:54
Bicycle Lee wrote:
Yes, it is safe to say that:) Hand tool tighten...nice and snug w/out putting your back into it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Re: torque specs
21 Feb 2009 11:55
It does matter, especially to keep from stripping out the aluminum cases by those of us who might be heavy handed. The Kawasaki manual shows specific torque specs for the most critical items but uses a more general table for other items based on the diameter of the bolt or screw and whether it is coarse or fine threads. Ed
- bountyhunter
Re: torque specs
21 Feb 2009 16:10
Most of the ones on mine came from the factory torqued to about 1000 ft-lbs. Had to use an impact driver on them, some of the screw crosses actually were twisted in the head after the3y camer loose.
- gane
Re: torque specs
21 Feb 2009 17:11
what ed said. 6mm 1.0, 4.5-6.5 ft lbs in this case. Pg. 40 in my factory KZ1000 manual G
[img][/img] 1977 KZ1000A1
