Valve cover gasket replacement
- fredgarvin42
21 Feb 2009 11:33 #266825
by fredgarvin42
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
Valve cover gasket replacement was created by fredgarvin42
I'm sure one of you knows the proper method to do this and since I'm unclear, hopefully the gods will know.
I'm going to replace my valve cover gasket and cam ends today I am unsure of what to use for sealant, if any. On cars I would typically install valve cover gaskets dry or with a light coating of gaskacinch (spelling?) but this is not a car so I figured I'd run this up the flagpole.
Also, any do's and dont's on the cam end pieces? Should I use red,blue, or no thread locker upon reassembly?
Thanks in advance!!!!
Peace
Peace
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
- trianglelaguna
- Thank you received: 235
21 Feb 2009 11:47 #266829
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Valve cover gasket replacement
you dont need locktight on the cover bolts and a "thin" bead of liquid gasket on the end plugs can be used
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- Thank you received: 10
21 Feb 2009 11:59 #266834
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Valve cover gasket replacement
put the valve cover on dry and no loctite needed
- MFolks
- Thank you received: 540
21 Feb 2009 12:13 #266836
by MFolks
Replied by MFolks on topic Valve cover gasket replacement
I've read/heard if the valve cover gasket is sprayed with a non stick cooking spray(like Pam) it will be able to be reused many times.
- bountyhunter
- Thank you received: 337
21 Feb 2009 16:07 #266870
by bountyhunter
Replied by bountyhunter on topic Valve cover gasket replacement
According to my FSM, the rubber plugs require sealant. Optional on the gasket, I use it across the tops of the plugs as they like to leak at the corners.
- fredgarvin42
22 Feb 2009 16:29 - 22 Feb 2009 18:45 #267250
by fredgarvin42
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
Replied by fredgarvin42 on topic Valve cover gasket replacement
Thanks!!!
OK. Swapped the gasket and seals with a little goo on the seals. I'm sure it will hold but now it has an exhaust leak on both sides of the valve cover...joy. Are the Exhaust recirculation devices interchangeable? I didn't note which side each one came from when I reinstalled them.
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
Last edit: 22 Feb 2009 18:45 by fredgarvin42. Reason: icon thingy
