Clutch basket nuts.....how tight?
- verybadmonkey
19 Feb 2009 10:54 #266183
by verybadmonkey
Clutch basket nuts.....how tight? was created by verybadmonkey
Hello everyone. I have a simple question cause the clymers manual has me all confused. How tight do you tighten the clutch basket screws? The ones with a spring behind them. The book says "tight", but what does that mean? Finger tight, as tight as I can with a handle driver, or ratchet tight.
- Thank you received: 2829
19 Feb 2009 11:28 #266190
by 650ed
Replied by 650ed on topic Clutch basket nuts.....how tight?
One more reason to buy a Kawasaki Factory Service Manual instead of Clymers. What model bike??
- verybadmonkey
19 Feb 2009 11:35 #266191
by verybadmonkey
Replied by verybadmonkey on topic Clutch basket nuts.....how tight?
Oops...its a 1980 kz750
- OnkelB
- Thank you received: 80
19 Feb 2009 11:54 #266194
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Clutch basket nuts.....how tight?
The Clymer manual for the 650s says 6-8 ft.lb/8-11 Nm, that should work for the 750s too. Best to tighten them in a criss-cross pattern little by little so the lifter plate moves in evenly.
- Link14
- Thank you received: 6
19 Feb 2009 12:52 - 19 Feb 2009 13:20 #266202
by Link14
Replied by Link14 on topic Clutch basket nuts.....how tight?
Looking at my 750 factory manual, it says to cross tighten the bolts evenly to 78 in-lbs
Last edit: 19 Feb 2009 13:20 by Link14.
