- Thank you received: 58
We have added 650 / 750 cams to our sute
- APE Jay
- Banned
- Dave Sloan
- Thank you received: 3
17 Feb 2009 01:42 - 17 Feb 2009 01:43 #265601
by Dave Sloan
Z650B2 - Injected
Replied by Dave Sloan on topic We have added 650 / 750 cams to our sute
Hey Jay great stuff, are the 60-061 cams lift supposed to be 384" not 284" :blink:
Z650B2 - Injected
Last edit: 17 Feb 2009 01:43 by Dave Sloan.
- nads.com
- Thank you received: 20
18 Feb 2009 01:11 #265836
by nads.com
Replied by nads.com on topic We have added 650 / 750 cams to our sute
doo the cams give the sute more lift like sholder pads doo? What kind of sute is it?
- Paling1
18 Feb 2009 04:08 #265850
by Paling1
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
Replied by Paling1 on topic We have added 650 / 750 cams to our sute
How do these cams compare to the '85 GPZ750A cams?
The description for the #60-061 cams is missing something... "Increased mid and upper end powerfor." ???
KZ700-A1 (1984)
- otakar
18 Feb 2009 08:09 - 18 Feb 2009 08:20 #265880
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic We have added 650 / 750 cams to our sute
Here is the info from the Web-Cam web sight, you can go to their web sight and get full timing cards which you can download. Web-Cam will also custom weld and grind a cam for the same price. You just tell them what you want. They have done a few sets of KZ1300 cams for me that were just fantastic.
Kawasaki KZ 650 (76-85) DOHC 8v
** Prices And Specifications Effective February 2009, And Are Subject To Change Without Notice. **
When a core is required for an item, the core charge will automatically be added to your cart when you add the item. You must return your re-workable OEM core within 180 days of purchase in order to receive a core refund. If we do not offer a core for your application, you need to call us first, and send your core in to be reground / hardwelded.
We use PayPal for payment processing so you know your transaction is safe and secure.
You do NOT need a PayPal account to shop with us, you can use your credit card.
You may also call us to order any of the listed items.
All in stock orders placed on-line Monday - Friday before 3:00pm Pacific, will ship the same day.
Camshaft Profiles:
Lift .365/.365
Duration 283°/283°
246°/246° @0.050"
Grind #118
Good overall performance for hot street engines. Requires Performance Valve Spring Kit. Price Per Set (2).
Accessories Required:
60-051
$470.00
Lift .395/.395
Duration 284°/284°
256°/256° @0.050"
Grind #110
Strong mid and upper end performance for street / strip. Requires Performance Valve Spring Kit. Price Per Set (2).
60-061
$470.00
Lift .400/.400
Duration 290°/290°
254°/254° @0.050"
Grind #189
Excellent mid and upper end performance for road race engines. Requires Exhaust System, High Compression Piston, and Performance Valve Spring Kit. Price Per Set (2).
60-191
$470.00
Lift .425/.425
Duration 287°/287°
260°/260° @0.050"
Grind #109
Designed for drag racing. Excellent top end performance. Requires Exhaust System, High Compression Piston, and Performance Valve Spring Kit. Check ALL clearances! Price Per Set (2).
60-071
$470.00
Here is the Link www.webcamshafts.com/
Camshaft Profiles:
Lift .365/.365
Duration 283°/283°
246°/246° @0.050"
Grind #118
60-051
$470.00
Lift .395/.395
Duration 284°/284°
256°/256° @0.050"
Grind #110
60-061
$470.00
Lift .400/.400
Duration 290°/290°
254°/254° @0.050"
Grind #189
60-191
$470.00
Lift .425/.425
Duration 287°/287°
260°/260° @0.050"
Grind #109
60-071
$470.00
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Feb 2009 08:20 by otakar.
