1981 CSR1000 Head question...
- Randall the Vandal
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
- APE Jay
- Banned
- Thank you received: 58
Jay
- kawsakiman
- Thank you received: 6
a j motor has different cam chain idlers then a kz motor.
totally different animal inside.
you must use a j block on a j motor and vice versa.
and as APE JAY said, a gpz uses 18 mm wristpins, a regular j uses 17 mm wristpins.
not as confusing as it sounds. got some pictures so we can help you more?
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
- keith1
- Thank you received: 2
- APE Jay
- Banned
he did ask if all 1000 cylinders were the same and the answer is no.
The early GPZ uses 17 mm pins. The 83, 84 with the bathtub head uses 18s.
