inch pounds to foot pounds
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
11 Feb 2009 21:11
I only have a foot pound torque wrench and I am torquing the head bolts on my 82 KZ1100 Spectre.
And some of the bolts are inch pounds how do I convert is it as easy as dividing the inch pounds by 12?
I need to know.
I need to know.
- Tony
- gane
Re: inch pounds to foot pounds
11 Feb 2009 22:05
Wagon.... Stop. put away your' Ft/lb torque wrench. at it's lightest setting all it can do is cost you money. a 6mm 1.0 thread bolt going into aluminum pulls threads @ 120 inch pounds. roughly the 1st graduation of your wrench, if unable to proqure a inch/lb wrench, go by feel. after cam tower bolts seat, the feel w/an 8" wrench is roughly what yoou would expect a walnut to crack at. balance is the key. a loose cam retainer is well loose.too tight strips threads,and possibly restricts oil bearing. it' your' call. luck G
[img][/img] 1977 KZ1000A1
- dman3998
11 Feb 2009 23:41
do yourself a favor and get a 1/4" or 3/8" drive inch/lbs torque wrench, WAY cheaper than a stripped thread or broken bolt. A beam type is accurate and can be had for like 20 - 30 bucks.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- mark1122
- Keep twisting it
12 Feb 2009 07:25
What they said x2.
Go buy the inch lb. wrench.
this will save u from a lot of brusing when u start to kick yourself in the head.lol
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Kawickrice
12 Feb 2009 11:15
I use my ft/lb wrench as a breaker bar when working on my bike. Get the inch/lb wrench. The ft/lb wrench works good on cars not bikes
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- bountyhunter
12 Feb 2009 13:45 - 12 Feb 2009 13:52
gane wrote:
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2696
Heed the advice. Harbor Freight has a decent clicker torque wrench which has a 200 inch-pound maximum scale that is good for camshafts, oil pan, cam cover, etc. I think it only costs about $20, I have been using one a long time.Wagon.... Stop. put away your' Ft/lb torque wrench. at it's lightest setting all it can do is cost you money. a 6mm 1.0 thread bolt going into aluminum pulls threads @ 120 inch pounds.
Last edit: 12 Feb 2009 13:52 by bountyhunter.
- bountyhunter
12 Feb 2009 13:50 - 12 Feb 2009 13:52
wagonmaster69 wrote:
This one will work pretty well for that:
www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=807
If those are like mine, they torque out to about 360 inch-pound ballpark (around 30 ft-lbs).I only have a foot pound torque wrench and I am torquing the head bolts on my 82 KZ1100 Spectre.
- wagonmaster69
12 Feb 2009 15:03
Thanks guys now I have to read how to adjust the cam chain and adjust the valves.
12 Feb 2009 15:47
Meanwhile, gane eagerly awaits further info from bountyhunter about HF's genuine Walnut Cracker torque-wrench valve adjuster. :laugh: :laugh: :laugh:
- gane
12 Feb 2009 18:18
Valve adjust(screw type) w/feeler in situ, should be just to where grape is deformed, G
